Relays activate at startup
RaphV57
#1 Post by RaphV57 » 26 May 2023, 23:18
I'm controlling a fan speed with double relay board and capacitors. When the wemos boot, the two relay are briefly activated. Have a look at my video to better understand.
Is there a way to avoid it?
Schematic
Re: Relays activate at startup
#2 Post by TD-er » 26 May 2023, 23:27
See "GPIO Behavior Summary" on this page: https://rabbithole.wwwdotorg.org/2017/0 ... -gpio.html
And the table on this page: https://lastminuteengineers.com/esp8266 ... reference/
Of course this page should be your first reference when picking pins to use :)
https://espeasy.readthedocs.io/en/lates ... on-esp8266
The only ones which are safe to use are GPIO 5 & 4 (D1/D2)
Second best are GPIO 14/12/13 (D5/D6/D7)
RaphV57
#3 Post by RaphV57 » 27 May 2023, 07:22
Thank you!
I got tricked once again with this GPIO selection... :oops:
#4 Post by TD-er » 27 May 2023, 13:17
RaphV57 wrote: 27 May 2023, 07:22 Thank you!
Happens to me all the time, that's why I created that table in the docs :)
