ESPEasy P2P Networking - sendTo - Help needed
Riewekooche
#1 Post by Riewekooche » 29 Jun 2023, 11:27
Dear friends,
at my ESP12f (Unit1) i messure the temperature with a DHT22.
The value is found at device task-1 DHTo#T1.
Now I need this value at my second ESP12f (Unit2) in the DummyDevice-task-4 (TaskValueSet 4,1,x)
First i activated the ESPEasy P2P in the Controller-menu at both ESPs. Then i inserted a rule at the sender:
on DHTo#T1 do
sendTo 1,"TaskValueSet 4,1,([DHTo#T1])"
In the log, the rule is executed, but i don't know how to get the sended values at the unit2.
What should i do?
Kind regards
Thomas
Re: ESPEasy P2P Networking - sendTo - Help needed
#2 Post by TD-er » 29 Jun 2023, 11:36
You can simply share a plugin/task directly to another node.
See for instructions here: https://espeasy.readthedocs.io/en/lates ... #c013-page
The sendto command is using the same p2p protocol as mentioned in that link.
Make sure the unit numbers are unique in your setup an all nodes participating use the same UDP port number (preferrably use port 8266)
N.B. you should not use () in the command.
The "sendto" command requires the unit number of the receiving node, so in your setup it should be something like this:
on DHTo#T1 do
  sendTo,2,"TaskValueSet 4,1,[DHTo#T1]"
Assuming you have given the units their own (unique) unit ID. Do not use unit ID 0 or 255.
On the receiving node you must have a dummy task at task-index 4.
Riewekooche
#3 Post by Riewekooche » 29 Jun 2023, 12:45
Hi TD-er,
i'd activated the P2P Network at both sides and used a wrong TaskValueSet (4 instead of 5).
Now it works :-)
#4 Post by TD-er » 29 Jun 2023, 12:48
Good to hear it is now working :)
Have fun!
#5 Post by Ath » 29 Jun 2023, 12:49
Riewekooche wrote: 29 Jun 2023, 12:45 Hi TD-er,
Now it works :-)
That was one of the reasons that support for taskname and taskvaluename was introduced for the TaskValue* group of commands ;)
So you could have used:
  sendTo,2,"TaskValueSet DHTremote,Temp,[DHTo#T1]"
assuming you named your dummy task "DHTremote" and used the value name "Temp"
Users browsing this forum: Anthropic Claude Bot [bot] and 3 guests
