Rules with an analog value
Dick60
#1 Post by Dick60 » 06 Aug 2023, 19:06
I have an ESP32 loaded with the latest firmware. Connected an LDR as an Analog device. That wordks fine, give s correct measurement (for me). Now I try to get a switch switching on a particular level, but the switch does not change from 0 to 1. It is al experimental, to learn more about Rules and read the documents related to this item but still I cannot see the problem in this script.
On ZP_220_verklikker#Analog do
If %eventvalue1%>2000
GPIO,21,1
Endif
Re: Rules with an analog value
#2 Post by Ath » 06 Aug 2023, 20:48
You can use the logevent command to show the current value:
    GPIO,21,1
  Endif
  LogEvent,"LDR Analog value: %eventvalue1%"
then look at the (serial) logging what's actually being measured, and if the event is being fired, as for this one to go, the Single event with all values: checkbox should be unchecked ;)
Dick60
#3 Post by Dick60 » 06 Aug 2023, 21:29
It was the checkbox for the single event that had to be unchecked. II was already starting to doubt myself; such a simple script and not getting that done yet??? :D Thanks for the help
