PN532 and Home Assistant
I have a nodemcu running the Release mega-20181022 stable version along with a PN532. I am able to read the tags. I have also integrated the same into my home assistant.
While setting up automation i found that home assistant does not realize the same tag being read multiple times. In order to avoid the same is there anyway i can use rules to reset the readings of the PN532 after 3 seconds of every read. i.e. once the card is detected, after 3 seconds, the value should be something other than what was read.
Thank you
Thank you
Re: PN532 and Home Assistant
Are the tag numbers integers or is there letters inside them? If they are numbers only (=integers) then you can store them inside the newly added internal variables (1...16) or use traditional dummy devices.
tag numbers are all intergers. sorry this is very new to me. can you tell me where can i find the internal variable or traditional dummy devices
If you look in the wiki regarding rules you get a good start. After that you can come here and I'll help you out.
so going through the rules this is what i came up with. the rfid is connected to i2c whichi would be GPIO-4 for SDA and GPIO-5 for SCL
On Rules#Timer=1 do
if[esp004#tag]>0
gpio,4,%value%
gpio,4,000000000
timerSet,1,3
is this correct
On Rules#Timer=1 do
if[esp004#tag]>0
gpio,4,%value%
gpio,4,000000000
timerSet,1,3
is this correct
No you need to create either a dummy device or use the newly added system variables. So either you do it like this:
Old way with dummy devices (I place them on task number 12 in this example, naming them Dummy#CurrentTag and Dummy#ZeroTag), if your esp004#tag device is on task number 1 and value number 1 this would then hopefully work.
New way would be to use this:
I'm typing this out of my head so please get back here if something is not working as you was hoping.
On System#Boot Do
taskValueSet,12,2,123456789
EndOn
On esp004#tag Do
taskValueSet,12,1,[esp004#tag] //Setting dummy vaue 1 to the tag code
TimerSet,1,3
EndOn
On Rules#Timer=1 Do
If [esp004#tag] = [Dummy#CurrentTag] //If the tag code is still the same after 3 seconds clear it
taskValueSet,1,1,[Dummy#ZeroTag]
EndIf
EndOn
On System#Boot Do
Let,1,123456789
EndOn
On esp004#tag Do
Let,2,[esp004#tag]
TimerSet,1,3
EndOn
On Rules#Timer=1 Do
If [esp004#tag] = %v2%
taskValueSet,1,1,%v1%
EndIf
EndOn
Let,1,123456789
Can you enlighten us about this new way?
It's only a couple of days old. I will add more info about it but in short:
Let,<value number 1...16>,<float>
Example
Let,1,10
Let,2,20
Publish,Answer/%v1%+%v2,(%v1%+%v2%)
This would render in this being published
Topic
Answer/10+20
Example
Let,1,10
Let,2,20
Topic
Answer/10+20
Ohhh great
Users browsing this forum: Ahrefs [Bot] and 2 guests
