Send IP address to mqtt
goczen
#1 Post by goczen » 21 Oct 2016, 18:31
Could you tell me, how I can send the %ip% to mqtt broker, I can send other datas like the temperature and analog input.
thank you
mgennip
Re: Send IP address to mqtt
#2 Post by mgennip » 21 Oct 2016, 19:07
This can only done if you can add some code to the mqtt plugin and compile the firmware yourself. Sending %ip% is not a standard feature. I would like to see this implemented also in the generic http plugin
papperone
#3 Post by papperone » 21 Oct 2016, 20:59
You can send it at boot or at a given interval using events.
goczen
#4 Post by goczen » 22 Oct 2016, 01:20
thanks a lot
I put it in the rules section and it works:
On System#Boot do //When the ESP boots, do
Publish /%sysname%/Bedroom/IPAddress,%ip%
timerSet,1,600 //Set Timer 1 for the next event in 10 minutes
papperone
#5 Post by papperone » 22 Oct 2016, 01:24
good to be helpful :)
f-fish
#6 Post by f-fish » 23 Oct 2016, 15:05
Thanks that is useful,
Would be cool to have both %sysname% and %ip% as part of http://www.esp8266.nu/index.php/SysInfo
Later Ferdie
Users browsing this forum: Anthropic Claude Bot [bot], Perplexity.ai [bot] and 12 guests
