Could you tell me, how I can send the %ip% to mqtt broker, I can send other datas like the temperature and analog input.
thank you
Send IP address to mqtt
Re: Send IP address to mqtt
This can only done if you can add some code to the mqtt plugin and compile the firmware yourself. Sending %ip% is not a standard feature. I would like to see this implemented also in the generic http plugin
You can send it at boot or at a given interval using events.
thanks a lot
I put it in the rules section and it works:
On System#Boot do //When the ESP boots, do
Publish /%sysname%/Bedroom/IPAddress,%ip%
timerSet,1,600 //Set Timer 1 for the next event in 10 minutes
good to be helpful
Thanks that is useful,
Would be cool to have both %sysname% and %ip% as part of http://www.esp8266.nu/index.php/SysInfo
Later Ferdie
Later Ferdie
