[Solved] Making Nodelist visible
I've got a question, must i fill in all my ESP's the same number to make de Nodelist visible?
Re: [Solved] Making Nodelist visible
yes you should use the same udp PORT in every unit
And do not forget to give each esp its own unit number. They are default all 0.
Yep, but isn't only submit
. But also reboot, and that wasn't in the wiki.
Users browsing this forum: Anthropic Claude Bot [bot] and 20 guests
