[Solved] Making Nodelist visible
ManS-H
#1 Post by ManS-H » 04 Nov 2016, 15:02
I've got a question, must i fill in all my ESP's the same number to make de Nodelist visible?
frank
Re: [Solved] Making Nodelist visible
#2 Post by frank » 06 Nov 2016, 20:43
yes you should use the same udp PORT in every unit
hvdwolf
#3 Post by hvdwolf » 06 Nov 2016, 22:15
And do not forget to give each esp its own unit number. They are default all 0.
ManS-H
#4 Post by ManS-H » 06 Nov 2016, 22:17
Yep, but isn't only submit
. But also reboot, and that wasn't in the wiki.
