I want to connect my WEMOS boards to a WIFI network (SSID).
My previous working network (SSID) is not available.
How do I change the EASYESP to use a different SSID if I cannot access the current configuration?
I have tried flashing the firmware again - via USB - but it is still inaccessible - does it keep the configuration intact although re-programmed?
Help needed.... Using Windows
How to change SSID?
How to change SSID?
Re: How to change SSID?
Use a terminal program like ESPlorer. You can view the settins with command: settings
With WifiSSID <SSID> and WifiKey <Wifi WPA key> you can change your settings.
Then Save and Reboot
Succes.
Succes.
When I connect using 57600 or 115200 or 9600 I don't get any response from the board.
Are you sure this works with ESPEASY firmware? or do I need a different baud rate?
Did you cross TX and RX?
Users browsing this forum: No registered users and 42 guests
