ESP Easy: ESP8266 R147
ravikjab
#1 Post by ravikjab » 04 Dec 2016, 20:38
I'm just new in this software.
I tray today use ESP Easy with my ESP-01 and configurate with Domiticz. I use version R120 of ESP EASY and it works with DS18B20. So I try connect my Relay switch but I couldn't switch from Domoticz. After that I also couldn't display Devices when I log on website my ESP Easy.
I also update to R147 but it doesn't help.
Please could anyone help me ?
ravikjab
Re: ESP Easy: ESP8266 R147
#2 Post by ravikjab » 04 Dec 2016, 20:55
when a try display Devices on Serial Monitor I have:
Exception (0):
epc1=0x3042f2a8 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff3620 end: 3fff3ad0 offset: 01a0
>>>stack>>>
3fff37c0: 30303030 30303030 30303030 30303030
3fff37d0: 30303030 30303030 30303030 30303030
3fff37e0: 30303030 30303030 30303030 30303030
3fff37f0: 30303030 30303030 30303030 30303030
3fff3800: 30303030 30303030 30303030 30303030
3fff3810: 30303030 30303030 30303030 30303030
3fff3820: 30303030 30303030 30303030 30303030
3fff3830: 30303030 30303030 30303030 30303030
3fff3840: 30303030 30303030 30303030 30303030
3fff3850: 30303030 30303030 30303030 30303030
3fff3860: 30303030 30303030 30303030 30303030
3fff3870: 30303030 30303030 30303030 30303030
3fff3880: 30303030 30303030 30303030 30303030
3fff3890: 00000030 00000000 00000000 00000000
3fff38a0: 00000000 6465756c 6d696365 34736c61
3fff38b0: 00000000 00000008 40101f52 00000002
3fff38c0: 00000005 3fff626c 0000010f 00000101
3fff38d0: 3fff5854 0000001f 00000015 3fff58c4
3fff38e0: 0000099f 0000099f 3fff58ac 0000000f
3fff38f0: 00000000 3fff5894 0000000f 00000000
3fff3900: 3fff587c 0000000f 00000000 3fff5734
3fff3910: 0000000f 00000000 3fff571c 0000000f
3fff3920: 00000000 3fff5704 0000000f 00000000
3fff3930: 3fff564c 0000000f 00000000 3fff56c4
3fff3940: 0000000f 00000000 3fff56ac 0000000f
3fff3950: 00000000 3fff5694 0000000f 00000000
3fff3960: 3fff567c 0000000f 00000000 3fff5664
3fff3970: 0000000f 00000000 3fff561c 0000000f
3fff3980: 00000000 3fff5634 0000000f 00000000
3fff3990: 00000003 3fff1416 00000004 3fff0a74
3fff39a0: 3fff1591 3fff1591 3fff15d1 4022565c
3fff39b0: 3fff4454 00000008 3fff3a00 40220a28
3fff39c0: 00000001 00000001 3fff474c 40212249
3fff39d0: 00000001 00000001 3fff3a00 402267de
3fff39e0: 00000000 00000000 3fff474c 40220a1e
3fff39f0: 3fff474c 3fff1b38 3fff474c 40220a5a
3fff3a00: 00000000 00000000 00000000 4022580c
3fff3a10: 3fff474c 3fff1b38 3fff1af8 40220aed
3fff3a20: 3fff4454 0000000f 00000008 4021eeac
3fff3a30: 3fff1b38 00000000 3fff2ab0 00000001
3fff3a40: 00000001 4021fce8 0000000f 40226cc8
3fff3a50: 00000000 00000000 3fff23d4 3fff2aa0
3fff3a60: 00000001 3fff1b1c 3fff1af8 40220d27
3fff3a70: 3fffdad0 3fff2aa0 40226438 3fff2ab0
3fff3a80: 3fffdad0 00000000 3fff0758 402264b0
3fff3a90: 3fffdad0 00000000 3fff0758 40213462
3fff3aa0: 00000000 00000000 3fff0758 40217320
3fff3ab0: 3fffdad0 00000000 3fff2a9a 40226484
3fff3ac0: feefeffe feefeffe 3fff2ab0 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
řŞU
ravikjab
#3 Post by ravikjab » 04 Dec 2016, 21:58
in LOG of ESP EASY I have:
244 : INIT : Booting Build nr:120
1130 : WIFI : Connecting... 1
5135 : WIFI : Connected!
5135 : INIT : I2C
6140 : INIT : Boot OK
6140 : INIT : Normal boot
36142 : WD : Uptime 0 ConnectFailures 0 FreeMem 28512
36991 : DS : Temperature: Error! (0-0-0-0-0-0-0-0)
37992 : DS : Temperature: Error! (-1--1--1--1--1--1--1--1)
66143 : WD : Uptime 1 ConnectFailures 0 FreeMem 28400
NightBird
#4 Post by NightBird » 05 Dec 2016, 11:10
first check your power supply. ESP chip may need more current (some peaks at about 300mA, not easy measurable with a multimeter, because very short).
A poor supply could cause ESP failures.
You seem to have problems after trying to activate a relay. The current needed by the relay coil may cause a glitch to the supply rails, and corrupt the ESP internal memory.
You can try to add a 470µF (or more) capacitor between +3v3 and GND (closest to the ESP module).
If it doesn't work, try to reflash your ESP.
Good luck ;)
ESPEasy running on ESP-12F self-made modules (with various sensors) and talking to Domoticz (hosted on RPi2)
ravikjab
#5 Post by ravikjab » 05 Dec 2016, 17:13
It doesn't help, I add 100uF.
I try also re-flash and still couldn't display devices, so perhaps I destroy my ESP during connect relay :-(.
NightBird
#6 Post by NightBird » 05 Dec 2016, 18:20
Which schematics do you use for relay control ?
If you made a mistake in relay wiring, it could damage only the GPIO you used...
Did you try to flash a more recent firmware ?
ravikjab
#7 Post by ravikjab » 05 Dec 2016, 23:44
I try connect this relay http://www.sainsmart.com/8-channel-dc-5 ... logic.html
in ESP Easy for devices i choose Swith and GPIO-2. On GPIO-0 i have connect DS18B20.
If only GPIO-2 is damege why I couldn't display devices i ESP EASY ?
I try flash with R120 and R147, on both versions was the same problem with devices?
Could you have older version to flash ?
NightBird
#8 Post by NightBird » 06 Dec 2016, 11:42
OK, this is a ready-to-use relay board.
I don't think you can damage your ESP with that kind of board.
Maybe your ESP has internal failure ?...
Anyway, you can find older releases here : https://sourceforge.net/projects/espeasy/files/
ravikjab
#9 Post by ravikjab » 06 Dec 2016, 12:44
You must to know that I remove jumper and connect 5V to pin JD-VCC.
Could this damage ?
NightBird
#10 Post by NightBird » 06 Dec 2016, 13:39
You're absolutely right. 5V can damage the ESP chip.
But you have removed the jumper before connecting 5V (to pin 3 I hope ?)
In that case, no damage to GPIO pin.
ESP8266 datasheet specify an operating voltage between 3.0 and 3.6V. Most regulators used on boards output 3.3V, so GPIO are able to deal with a voltage between 0V (GND) and 3.3V (Vcc).
If you remove the jumper and connect 5V to the pin 3, there's no voltage applied to the optocoupler, and it doesn't work anymore.
You must connect +3.3V to pin 2 (central pin) to allow GPIO2 activate the optocoupler and switch the relay.
In case of doubt, try to use another GPIO.
BTW, is the web configuration page available ? Why do you keep on using serial ?
Users browsing this forum: Bing [Bot] and 27 guests
