WH1285 TX (WH-5) Temp & Humidity sensor
Post here about devices that are not yet or not fully supported
xztraz
#1 Post by xztraz » 19 Jan 2017, 15:44
Tried with a weather sensor . I Can se debug log for it but no decoding of data.
From
http://www.ebay.co.uk/itm/261788376051? ... EBIDX%3AIT
Package for sensor is marked
WH1285TX
Sensor marked
Imagitronix
WH5. (likley a Fine Offset sensor alecro)
No dipswitches. addressing should be done automaticly (time based?)
Should report
Temperature
Humidity
Some dubug
20;0A;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,6990;
20;0B;DEBUG;Pulses=48;Pulses(uSec)=450,840,1290,840,1290,840,360,840,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,6990;
20;0C;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
Awesome project!
Best regards
Xztraz
Stuntteam
Site Beheer
Re: WH1285 TX (WH-5) Temp & Humidity sensor
#2 Post by Stuntteam » 19 Jan 2017, 17:22
Ok, we will take a look..
xztraz
#3 Post by xztraz » 19 Jan 2017, 19:28
If there is anything i can help with please tell.
More logs with device os so.
xztraz
#4 Post by xztraz » 19 Jan 2017, 20:11
Tried to sort out some log for the sensor after i put it in the cooler 24C->10C. humidity probably changes too
Sorted:
20;1C;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1350,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,6990;
20;24;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,6990;
20;2B;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1350,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,6990;
20;40;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1350,870,390,870,1350,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1350,900,1380,870,1380,870,390,870,390,870,1350,870,390,870,1380,870,390,870,390,870,390,870,1380,870,390,6990;
20;4C;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1350,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,1350,900,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,6990;
20;58;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,900,390,870,1380,870,390,870,1380,870,1350,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,6990;
20;6B;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,6990;
20;89;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,900,390,870,1380,870,390,870,1380,870,1350,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,900,390,870,1380,870,1380,870,390,870,1350,870,390,870,1380,870,1380,870,390,6990;
20;8D;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,6990;
RAW Log (with other sensors)
1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfudebug=on;
20;03;RFUDEBUG=ON;
10;rfdebug=on;
20;04;RFDEBUG=ON;
10;rfdebug=off;
20;05;RFDEBUG=OFF;
10;rfudebug=off;
20;06;RFUDEBUG=OFF;
20;07;Mebus;ID=9401;TEMP=0015;
20;08;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;09;Mebus;ID=9401;TEMP=0014;
10;rfdebug=on;
20;0A;RFDEBUG=ON;
10;rfudebug=on;
20;0B;RFUDEBUG=ON;
10;rfudebug=off;
20;0C;RFUDEBUG=OFF;
10;rfudebug=on;
20;0D;RFUDEBUG=ON;
10;rfdebug=off;
20;0E;RFDEBUG=OFF;
10;rfdebug=on;
20;0F;RFDEBUG=ON;
20;10;DEBUG;Pulses=94;Pulses(uSec)=420,900,390,870,390,870,390,870,390,870,390,900,390,870,1380,870,390,870,1380,870,1350,900,1350,870,390,870,1350,870,390,870,1350,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,6990;
20;11;DEBUG;Pulses=46;Pulses(uSec)=1380,840,1290,840,1290,840,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,6990;
20;12;DEBUG;Pulses=44;Pulses(uSec)=420,1920,330,4500,330,1920,330,4500,330,4500,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,3450;
20;13;DEBUG;Pulses=36;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,5460;
20;14;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,4470,330,1920,330,4470,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6840;
20;15;DEBUG;Pulses=36;Pulses(uSec)=390,4470,330,1920,330,4500,330,4500,330,1860,390,1920,330,4470,360,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1020;
20;16;DEBUG;Pulses=38;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;17;DEBUG;Pulses=28;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,360,1920,330,1920,330,6990;
20;18;DEBUG;Pulses=511;Pulses(uSec)=450,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,930,330,960,300,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1950,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1890,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,960,330,1920,330,930,330,930,330,1890,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,930,330,1920,330,960,300,960,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,1950,300,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1890,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,300,960,330,1920,360,1920,330,3870,330,1920,330,930,330,930,330,1890,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1890,330,930,330;
20;19;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
10;rfudebug=off;
20;1A;RFUDEBUG=OFF;
20;1B;DEBUG;Pulses=30;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,4470,330,1410;
20;1D;DEBUG;Pulses=40;Pulses(uSec)=420,1920,330,4500,330,1920,330,4470,330,4500,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,3420;
20;1E;DEBUG;Pulses=24;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1410;
20;1F;DEBUG;Pulses=28;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4320;
20;20;DEBUG;Pulses=34;Pulses(uSec)=390,4260,300,1830,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1290;
20;21;DEBUG;Pulses=44;Pulses(uSec)=390,1920,330,4470,330,1920,330,4500,330,4500,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1170;
20;22;DEBUG;Pulses=511;Pulses(uSec)=450,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1890,330,930,330,930,330,960,330,1920,330,1890,330,1890,330,1950,300,1920,330,1920,330,930,330,960,330,1920,330,960,300,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1890,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1890,330,930,330,930,330,930,330,1920,330,1920,330,1890,330,1920,330,1920,330,1920,330,930,330,930,330,1950,300,930,330,930,330,930,330,1920,330,1890,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,960,330,930,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,300,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1890,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1890,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1890,330,1920,330,1920,330,1920,330,1890,330,1920,330,960,330,960,330,1890,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,300,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330;
20;23;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;25;DEBUG;Pulses=46;Pulses(uSec)=1380,840,1290,840,1290,840,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,6990;
20;26;DEBUG;Pulses=46;Pulses(uSec)=420,1920,330,4500,330,1920,330,4470,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,180;
20;27;DEBUG;Pulses=50;Pulses(uSec)=420,4470,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1740;
20;28;DEBUG;Pulses=36;Pulses(uSec)=390,4500,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1170;
20;29;DEBUG;Pulses=28;Pulses(uSec)=360,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,5010;
20;2A;DEBUG;Pulses=44;Pulses(uSec)=390,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;2C;DEBUG;Pulses=511;Pulses(uSec)=390,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1890,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,930,330,930,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,300,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1890,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,960,300,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,300,930,330,930,330,1890,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,960,300,960,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,360,1920,330,930,330,960,330,1920,330,960,330,960,330,1920,330,1920,330,1950,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,300,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,300,960,330,930,330,930,330,930,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,300,960,330,1920,330,960,330,930,330,930,330,1890,330,1920,330,1920,330,1920,330,1890,330,1920,330,930,330,930,330,1920,330,930,330;
20;2D;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;2E;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,4500,330,1920,330,4500,330,4500,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;2F;Mebus;ID=9401;TEMP=0014;
20;30;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,4500,330,1920,330,4470,330,4500,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;31;DEBUG;Pulses=36;Pulses(uSec)=390,1830,300,1800,330,1800,300,1890,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;32;DEBUG;Pulses=46;Pulses(uSec)=390,1830,300,4260,330,1860,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;33;DEBUG;Pulses=42;Pulses(uSec)=390,1800,300,4260,330,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;34;DEBUG;Pulses=36;Pulses(uSec)=390,1800,330,4350,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,3900;
20;35;DEBUG;Pulses=52;Pulses(uSec)=390,4260,300,4350,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;36;DEBUG;Pulses=38;Pulses(uSec)=390,1830,300,1830,300,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;37;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;38;Mebus;ID=9401;TEMP=0013;
20;39;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;3A;DEBUG;Pulses=34;Pulses(uSec)=360,1800,330,1800,300,1830,300,1890,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,6750;
20;3B;DEBUG;Pulses=46;Pulses(uSec)=360,1830,300,4260,330,1830,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;3C;DEBUG;Pulses=40;Pulses(uSec)=390,4260,330,1830,330,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;3D;DEBUG;Pulses=42;Pulses(uSec)=390,1830,300,4290,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;3E;DEBUG;Pulses=42;Pulses(uSec)=390,1800,330,4260,330,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;3F;DEBUG;Pulses=42;Pulses(uSec)=390,1800,300,4260,300,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;41;DEBUG;Pulses=46;Pulses(uSec)=1380,840,1290,840,1290,840,1380,870,1380,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1380,870,390,6990;
20;42;DEBUG;Pulses=511;Pulses(uSec)=480,3870,330,1920,330,960,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,300,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1890,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,300,960,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3900,330,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,300,960,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,300,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330;
20;43;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;44;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,1920,330,4500,330,4470,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;45;Mebus;ID=9401;TEMP=0012;
20;46;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4470,330,4470,330,4470,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;47;DEBUG;Pulses=36;Pulses(uSec)=390,1830,300,1830,300,1830,300,1890,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;48;DEBUG;Pulses=46;Pulses(uSec)=390,1830,300,4260,330,1860,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;49;DEBUG;Pulses=42;Pulses(uSec)=390,1830,300,4260,300,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;4A;DEBUG;Pulses=42;Pulses(uSec)=390,1800,330,4320,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,360,4470,330,1920,330,1920,330,6990;
20;4B;DEBUG;Pulses=42;Pulses(uSec)=390,1800,300,4350,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;4D;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4500,330,4500,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;4E;DEBUG;Pulses=36;Pulses(uSec)=390,1830,300,1800,330,1830,300,1890,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;4F;DEBUG;Pulses=46;Pulses(uSec)=390,1830,300,4260,330,1860,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;50;DEBUG;Pulses=42;Pulses(uSec)=390,1800,300,4260,330,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;51;DEBUG;Pulses=42;Pulses(uSec)=390,1830,300,4350,330,1920,330,1920,330,1920,360,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;52;DEBUG;Pulses=42;Pulses(uSec)=390,1800,330,4320,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,300,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;53;DEBUG;Pulses=42;Pulses(uSec)=390,1800,300,4320,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;54;DEBUG;Pulses=42;Pulses(uSec)=390,1830,300,4350,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,6990;
20;55;DEBUG;Pulses=42;Pulses(uSec)=390,1800,330,4320,360,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;56;DEBUG;Pulses=511;Pulses(uSec)=450,3870,330,1920,330,930,330,960,330,1920,330,960,330,960,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,360,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1890,330,1920,330,1920,330,1920,330,1890,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1890,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1890,330,1920,330,1920,330,1890,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,930,330,930,300,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3900,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,300,1920,330,930,330,960,330,1920,330,960,330;
20;57;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;59;DEBUG;Pulses=48;Pulses(uSec)=930,840,360,840,360,840,1320,840,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,6990;
20;5A;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1890,330,4500,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;5B;Mebus;ID=9401;TEMP=0011;
20;5C;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;5D;DEBUG;Pulses=34;Pulses(uSec)=390,1800,300,1800,300,1830,300,1890,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;5E;DEBUG;Pulses=46;Pulses(uSec)=390,1830,300,4260,330,1800,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;5F;DEBUG;Pulses=40;Pulses(uSec)=390,4260,300,1830,300,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,4590;
20;60;DEBUG;Pulses=34;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;61;DEBUG;Pulses=46;Pulses(uSec)=390,1800,300,4260,330,1830,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;62;DEBUG;Pulses=40;Pulses(uSec)=390,4260,330,1800,330,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;63;DEBUG;Pulses=58;Pulses(uSec)=420,4470,330,4470,330,4470,330,4470,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;64;Mebus;ID=9401;TEMP=000f;
20;65;DEBUG;Pulses=58;Pulses(uSec)=420,4470,330,4470,330,4470,330,4500,330,4500,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,4500,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;66;DEBUG;Pulses=40;Pulses(uSec)=90,4260,330,1800,300,1830,330,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;67;DEBUG;Pulses=48;Pulses(uSec)=390,1800,330,1830,300,4290,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;68;DEBUG;Pulses=42;Pulses(uSec)=360,1830,300,4350,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;69;DEBUG;Pulses=46;Pulses(uSec)=390,1830,300,4260,300,1890,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,4500,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;6A;DEBUG;Pulses=44;Pulses(uSec)=390,4260,300,1830,300,4440,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;6C;DEBUG;Pulses=511;Pulses(uSec)=450,3870,330,1920,330,960,300,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,360,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,960,330,930,330,930,330,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,960,300,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1890,330,3870,330,1920,330,930,330,960,330,1920,300,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,300,960,330,930,330,930,330,1890,330,930,330,930,330,930,330,1920,330,1920,330,1920,300,1920,330,1920,330,1920,330,930,330,930,330,1890,330,930,330;
20;6D;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;6E;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;6F;Mebus;ID=9401;TEMP=0011;
20;70;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;71;DEBUG;Pulses=34;Pulses(uSec)=390,1800,330,1800,330,1830,300,1890,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;72;DEBUG;Pulses=46;Pulses(uSec)=390,1830,300,4260,300,1800,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;73;DEBUG;Pulses=40;Pulses(uSec)=390,4260,330,1800,330,1860,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1950,300,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;74;DEBUG;Pulses=42;Pulses(uSec)=390,1830,300,4260,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;75;DEBUG;Pulses=42;Pulses(uSec)=390,1800,300,4260,330,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;76;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,6990;
20;77;FineOffset;ID=0056;TEMP=0255;HUM=28;
20;78;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,4770;
20;79;Mebus;ID=9401;TEMP=0011;
20;7A;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;7B;DEBUG;Pulses=34;Pulses(uSec)=390,1830,300,1800,330,1830,300,1890,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;7C;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;7D;DEBUG;Pulses=34;Pulses(uSec)=390,1800,330,1800,330,1830,300,1890,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;7E;DEBUG;Pulses=56;Pulses(uSec)=420,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,6240;
20;7F;DEBUG;Pulses=26;Pulses(uSec)=390,1830,300,1800,330,1830,300,1890,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,6990;
20;80;DEBUG;Pulses=511;Pulses(uSec)=450,3900,330,1920,330,960,300,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3900,330,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,1950,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,930,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,300,1920,330,1890,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330;
20;81;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;82;DEBUG;Pulses=48;Pulses(uSec)=420,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4500,330,1920,360,4470,330,1920,330,1920,330,6990;
20;83;DEBUG;Pulses=38;Pulses(uSec)=360,1800,330,1830,300,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,3840;
20;84;DEBUG;Pulses=34;Pulses(uSec)=390,1830,300,4260,330,1800,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,630;
20;85;DEBUG;Pulses=102;Pulses(uSec)=420,1920,330,1920,330,4500,330,30,390,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1350,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,4860;
20;86;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;87;Mebus;ID=9401;TEMP=0011;
20;88;DEBUG;Pulses=48;Pulses(uSec)=420,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,6990;
20;8A;FineOffset;ID=0056;TEMP=023d;HUM=27;
20;8B;DEBUG;Pulses=511;Pulses(uSec)=480,3870,330,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1890,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,300,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,930,330,1890,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3900,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,930,330,930,330,960,330,1950,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1890,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,300,960,330,930,330,1920,300,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1890,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1890,330,930,330,930,330,1920,330,1890,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,2160,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,1890,330,1920,330,3870,360,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330;
20;8C;Tunex;ID=9302;TEMP=0023;HUM=35;BAT=OK;
20;8E;FineOffset;ID=0056;TEMP=0232;HUM=25;
xztraz
#5 Post by xztraz » 20 Jan 2017, 10:55
Just got this from the seller. Awesome guy!
Stuntteam
Site Beheer
#6 Post by Stuntteam » 21 Jan 2017, 00:46
Check your email re. a test version..
xztraz
#7 Post by xztraz » 22 Jan 2017, 11:08
That was quick!
Just tested and got this in the log now
20;07;AlectoV3;ID=0056;TEMP=00dc;HUM=28;BAT=OK;
Took out the batteries from sensor and put them back
and the sensor now looks like
20;40;AlectoV3;ID=00ea;TEMP=00f3;HUM=2a;BAT=OK;
So it changes adress when restarted. nothing unsuspected.
Temp in domoticz show up as 22,5C that seem to be spot on. shall try humidity during the day. it says 22% now
Awesome work guys!!
The seller also asked if Rflink is ASK and or FSK. he seem to be able to get datasheets for some other sensors too with baro and such. but they are FSK
Full log (before firmware and with test)
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
10;status;
20;03;Tunex;ID=9302;TEMP=0017;HUM=35;BAT=OK;
10;rfdebug=on;
20;04;RFDEBUG=ON;
20;05;DEBUG;Pulses=28;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;06;DEBUG;Pulses=42;Pulses(uSec)=390,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,5520;
20;07;DEBUG;Pulses=24;Pulses(uSec)=420,1950,300,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,1920,330,5160;
20;08;DEBUG;Pulses=44;Pulses(uSec)=390,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,720;
20;09;DEBUG;Pulses=32;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,1920,330,5280;
20;0A;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1350,900,390,870,390,870,1380,870,390,870,390,6990;
20;0B;DEBUG;Pulses=48;Pulses(uSec)=930,840,360,840,360,840,1290,840,360,870,1380,870,1380,870,390,870,1350,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1350,870,390,870,390,6990;
20;0C;DEBUG;Pulses=511;Pulses(uSec)=480,3900,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,300,1920,330,960,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,960,330,960,330,930,330,930,330,930,330,930,330,1920,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,960,300,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,960,330,960,330,930,330,930,330,1920,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,960,330,960,330,1890,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1890,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,960,330,930,330,960,330,930,330,930,330,930,330,1920,330,960,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,300,960,330,960,330,1920,330,930,300,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,300,1920,330,960,330,960,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,960,330,930,330,930,330,960,330,930,330,930,330,1920,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,300,960,330,960,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3900,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,300,960,330,960,330,930,330,960,330,930,330,930,330,930,330,1920,330,960,330,1920,330,1920,570,1920,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1950,300,960,330,960,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,930,330,1920,330,930,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,960,300,930,330,1920,330,960,330;
20;0D;Tunex;ID=9302;TEMP=0017;HUM=35;BAT=OK;
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R46;
10;version;
20;01;VER=1.1;REV=46;BUILD=00;
10;status;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=511;Pulses(uSec)=450,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,300,930,330,960,330,960,330,930,330,930,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,960,330,960,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,960,330,1920,300,930,330,960,330,930,300,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,960,300,960,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,960,330,930,330,1920,330,1920,330,3900,300,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,960,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,930,330,960,330,1920,330,930,330,960,330,960,330,1920,330,1920,330,3900,330,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,960,330,930,330,930,330,960,330,930,330,930,330,1920,330,1920,330,960,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,960,330,960,300,1920,330,930,330;
20;05;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;06;DEBUG;Pulses=94;Pulses(uSec)=420,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1350,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,6990;
13
20;08;DEBUG;Pulses=36;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4500,330,1920,330,1920,330,6810;
20;09;DEBUG;Pulses=40;Pulses(uSec)=390,1830,300,4260,300,1860,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,2820;
20;0A;DEBUG;Pulses=48;Pulses(uSec)=390,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;0B;DEBUG;Pulses=24;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;0C;DEBUG;Pulses=38;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;0D;DEBUG;Pulses=48;Pulses(uSec)=420,1920,330,1920,330,4470,330,4470,330,4470,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4110;
20;0E;DEBUG;Pulses=94;Pulses(uSec)=420,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,6990;
13
20;0F;AlectoV3;ID=0056;TEMP=00dd;HUM=28;BAT=OK;
20;10;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,1920,330,4470,330,4500,330,4500,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,2250;
20;11;Mebus;ID=9401;TEMP=0003;
20;12;DEBUG;Pulses=26;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,3690;
20;13;DEBUG;Pulses=511;Pulses(uSec)=480,3870,330,1920,330,930,330,930,330,1920,330,960,330,960,330,1920,330,1950,330,1920,330,930,330,960,330,1920,330,930,330,960,330,930,330,930,300,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,960,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,960,300,960,330,960,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,960,300,930,330,1920,330,1920,330,3870,330,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,930,330,930,330,1920,330,1920,330,960,330,960,300,930,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,300,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,960,300,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,300,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,300,960,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,960,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1890,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,300,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,960,330,1920,330,1920,330,960,330,930,330,930,300,1920,330,1920,330,1920,330,2160,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,930,330,930,330,960,330,930,330,1920,330,1890,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330;
20;14;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;15;DEBUG;Pulses=44;Pulses(uSec)=420,4470,330,1920,330,1920,330,4500,330,1920,330,4440,390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,2730;
20;16;DEBUG;Pulses=48;Pulses(uSec)=390,1830,300,1890,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,3540;
20;17;DEBUG;Pulses=28;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,3930;
20;18;DEBUG;Pulses=32;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,2460;
20;19;DEBUG;Pulses=48;Pulses(uSec)=420,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;1A;DEBUG;Pulses=26;Pulses(uSec)=390,1830,300,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,3510;
20;1B;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,6990;
13
20;1C;AlectoV3;ID=0056;TEMP=00dd;HUM=28;BAT=OK;
20;1D;DEBUG;Pulses=38;Pulses(uSec)=390,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1890,360,1920,330,1920,330,1920,330,1920,330,4470,330,1170;
20;1E;DEBUG;Pulses=30;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;1F;DEBUG;Pulses=42;Pulses(uSec)=390,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4470,330,1920,330,1920,330,390;
20;20;DEBUG;Pulses=32;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4020;
20;21;DEBUG;Pulses=28;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,690;
20;22;DEBUG;Pulses=511;Pulses(uSec)=420,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,960,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3900,330,1920,330,960,330,930,330,1920,330,930,330,960,300,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,300,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,360,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,960,300,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,960,330,960,330,930,330,1920,330,1920,300,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,960,330,930,330,930,330,930,330,930,330,1920,330,1950,300,960,330,960,300,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,300,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,960,330,930,330,930,330,930,330,930,330,1920,330,1920,300,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,960,330,930,330,960,330,960,330,930,330,930,330,1920,330,1920,330,930,300,960,330,930,330,1920,330,1920,330,1920,330,2160,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1890,330,960,330,930,330,1920,300,960,330;
20;23;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;24;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,390,870,1350,870,390,870,1380,870,390,870,1380,870,1350,870,1380,870,390,870,1350,870,1380,870,390,870,390,870,390,870,1350,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,6990;
80
20;25;DEBUG;Pulses=48;Pulses(uSec)=1200,840,360,840,360,840,360,840,1290,870,390,870,1350,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,1350,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1350,6990;
20;26;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1350,870,1380,870,1350,870,390,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1350,900,390,870,390,870,1350,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,1380,870,1350,870,390,870,1350,870,390,6990;
80
20;27;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,4500,330,1920,330,1920,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1410;
20;28;Mebus;ID=9401;TEMP=0004;
20;29;DEBUG;Pulses=34;Pulses(uSec)=420,1920,330,4470,330,1920,330,1920,330,4500,330,1920,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1350;
20;2A;DEBUG;Pulses=40;Pulses(uSec)=420,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,5280;
20;2B;DEBUG;Pulses=38;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,2670;
20;2C;DEBUG;Pulses=28;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1500;
20;2D;DEBUG;Pulses=28;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,6630;
20;2E;DEBUG;Pulses=30;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,6990;
20;2F;DEBUG;Pulses=36;Pulses(uSec)=390,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,3090;
20;30;DEBUG;Pulses=34;Pulses(uSec)=420,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,600;
20;31;DEBUG;Pulses=26;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,1920,330,4500,330,1920,330,1920,330,2760;
20;32;DEBUG;Pulses=36;Pulses(uSec)=390,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1920,330,1920,330,1920,330,3870;
20;33;DEBUG;Pulses=36;Pulses(uSec)=390,1890,330,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,1410;
20;34;DEBUG;Pulses=511;Pulses(uSec)=480,3900,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,300,930,330,930,330,1920,330,930,330,960,330,960,330,930,330,930,330,960,330,930,330,1920,330,1920,330,930,330,960,300,960,330,1920,330,1920,300,1920,330,1920,330,960,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,960,300,930,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,300,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,300,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,300,960,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,960,330,960,330,930,330,960,330,930,330,960,330,1920,330,1920,330,930,330,960,300,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,960,330,960,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,930,330,930,330,960,330,1920,330,1920,330,960,330,960,330,930,330,1920,330,1920,330,1920,330,2160,330,930,330,930,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,960,330,930,300,960,330,930,330,1920,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330;
20;35;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;36;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,6990;
13
20;37;AlectoV3;ID=00ea;TEMP=00f1;HUM=2e;BAT=OK;
20;38;DEBUG;Pulses=32;Pulses(uSec)=360,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,630;
20;39;DEBUG;Pulses=40;Pulses(uSec)=390,4410,330,4500,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1950,300,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4320;
20;3A;DEBUG;Pulses=26;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;3B;DEBUG;Pulses=28;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,60;
20;3C;DEBUG;Pulses=26;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4500,330,1920,330,1920,330,6270;
20;3D;DEBUG;Pulses=28;Pulses(uSec)=360,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4500,330,330;
20;3E;DEBUG;Pulses=38;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1950,330,1920,330,4500,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;3F;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,900,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1350,6990;
13
20;41;DEBUG;Pulses=511;Pulses(uSec)=480,3870,330,1920,330,960,300,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,960,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,960,330,960,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,960,300,930,330,1920,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,960,330,960,300,960,330,930,330,960,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1950,300,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,960,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,300,930,330,930,330,930,330,930,330,930,330,930,330,1920,300,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,960,330,1920,300,1920,330,3900,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1950,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,960,330,930,330,930,330,960,330,930,330,1920,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1890,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,960,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1890,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,960,300,960,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1890,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330;
20;42;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;43;DEBUG;Pulses=26;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;44;DEBUG;Pulses=44;Pulses(uSec)=390,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,4020;
20;45;DEBUG;Pulses=38;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4470,330,1950,300,1920,330,6990;
20;46;DEBUG;Pulses=36;Pulses(uSec)=420,1830,300,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,450;
20;47;DEBUG;Pulses=38;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;48;DEBUG;Pulses=42;Pulses(uSec)=390,1830,300,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;49;DEBUG;Pulses=38;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;4A;DEBUG;Pulses=32;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,5070;
20;4B;DEBUG;Pulses=104;Pulses(uSec)=390,1920,330,1920,330,4500,330,4470,330,1860,390,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1350,900,390,870,390,870,1350,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1350,870,390,870,1380,870,1380,6990;
20;4C;DEBUG;Pulses=40;Pulses(uSec)=570,840,1290,840,360,840,360,840,1320,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1350,900,390,870,1380,870,1380,6990;
20;4D;DEBUG;Pulses=52;Pulses(uSec)=420,4500,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,2790;
20;4E;DEBUG;Pulses=26;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4200;
20;4F;DEBUG;Pulses=58;Pulses(uSec)=390,1830,300,1890,330,4500,330,4500,330,4470,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;50;Mebus;ID=9401;TEMP=0003;
20;51;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,1920,330,4470,330,4500,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;52;DEBUG;Pulses=511;Pulses(uSec)=420,3870,330,1920,330,930,330,960,330,1920,330,930,330,960,330,1950,300,1920,330,1920,330,960,330,960,330,1920,330,930,330,930,330,930,330,930,330,960,330,960,330,930,330,1920,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1890,330,930,330,960,330,1920,330,930,330,960,330,930,330,930,330,960,330,960,300,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,960,330,1920,300,960,330,960,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,960,330,930,330,930,330,960,330,1920,330,1920,330,930,330,960,330,960,330,1920,300,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3900,330,1920,330,960,330,930,300,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,960,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3900,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1950,330,930,300,960,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,2160,330,960,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3900,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,930,330,960,300,960,330,930,330,930,330,930,330,1920,330,1920,330,960,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330;
20;53;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;54;DEBUG;Pulses=32;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,2070;
20;55;DEBUG;Pulses=40;Pulses(uSec)=390,4470,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,1770;
20;56;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,1920,330,4500,330,4500,330,4500,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;57;Mebus;ID=9401;TEMP=0003;
20;58;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,900,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1350,900,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,900,390,870,390,870,390,6990;
13
20;59;AlectoV3;ID=00ea;TEMP=00f2;HUM=26;BAT=OK;
20;5A;DEBUG;Pulses=38;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,4470,330,1920,330,1920,330,6990;
20;5B;DEBUG;Pulses=30;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,3870;
20;5C;DEBUG;Pulses=26;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,3450;
20;5D;DEBUG;Pulses=44;Pulses(uSec)=420,1920,330,1920,330,4470,330,4470,330,4470,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1230;
20;5E;DEBUG;Pulses=46;Pulses(uSec)=420,4470,330,4500,330,1830,420,1920,330,4500,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4200;
20;5F;DEBUG;Pulses=48;Pulses(uSec)=390,1800,300,1830,300,4440,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,5010;
20;60;DEBUG;Pulses=38;Pulses(uSec)=360,1890,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,4500,330,1920,330,1920,330,5430;
20;61;DEBUG;Pulses=38;Pulses(uSec)=390,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,5880;
20;62;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1350,870,390,870,1380,870,1380,6990;
13
20;63;AlectoV3;ID=00ea;TEMP=00f0;HUM=24;BAT=OK;
20;64;DEBUG;Pulses=511;Pulses(uSec)=480,3900,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1920,330,960,330,960,330,1920,330,930,330,960,330,930,330,960,330,930,330,930,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,960,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,960,330,960,330,930,330,930,330,930,330,960,330,960,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,1920,300,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,300,960,330,930,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,300,1920,330,930,330,930,300,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1890,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,960,330,1920,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,930,330,930,330,1920,300,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,960,330,930,330,960,330,960,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,930,330,930,330,1920,330,960,330,960,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,960,330,930,330,930,330,930,330,960,330,930,330,960,330,1920,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330;
20;65;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
20;66;DEBUG;Pulses=42;Pulses(uSec)=390,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,4500,330,1920,330,1920,330,150;
20;67;DEBUG;Pulses=38;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;68;DEBUG;Pulses=40;Pulses(uSec)=390,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4470,330,1920,330,1920,330,6630;
20;69;DEBUG;Pulses=24;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,2790;
20;6A;DEBUG;Pulses=24;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1080;
20;6B;DEBUG;Pulses=48;Pulses(uSec)=390,1920,330,1920,330,4500,330,4500,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,3780;
20;6C;DEBUG;Pulses=42;Pulses(uSec)=420,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4470,330,1920,330,4500,330,1920,330,1920,330,6990;
20;6D;DEBUG;Pulses=38;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4470,330,1920,330,1920,330,630;
20;6E;DEBUG;Pulses=36;Pulses(uSec)=390,1920,330,1920,330,4470,330,4470,330,4470,330,1920,330,1920,330,4500,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1800;
20;6F;DEBUG;Pulses=36;Pulses(uSec)=420,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4470,330,1920,330,1920,330,4560;
20;70;DEBUG;Pulses=36;Pulses(uSec)=420,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4470,330,1920,330,3630;
20;71;DEBUG;Pulses=58;Pulses(uSec)=390,1920,330,1920,330,4500,330,4500,330,4470,330,1920,330,1920,330,4470,330,1920,330,4470,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4500,330,4500,330,1920,330,4500,330,1920,330,1920,330,6990;
20;72;Mebus;ID=9401;TEMP=0003;
20;73;DEBUG;Pulses=58;Pulses(uSec)=420,1920,330,1920,330,4500,330,4500,330,4500,330,1920,330,1920,330,4470,330,1920,330,4500,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,1920,330,4470,330,4500,330,1920,330,4470,330,1920,330,1920,330,6990;
20;74;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,900,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,6990;
13
20;75;AlectoV3;ID=00ea;TEMP=00ee;HUM=23;BAT=OK;
20;76;DEBUG;Pulses=511;Pulses(uSec)=480,3870,330,1920,330,930,330,930,330,1920,330,930,330,960,330,1920,330,1920,330,1890,330,930,330,960,330,1920,330,930,330,960,330,930,330,930,330,930,330,930,330,960,330,1920,330,1920,330,930,330,960,330,930,330,1920,330,1890,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,960,330,930,330,1920,330,960,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,930,330,930,330,960,330,930,330,930,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,960,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,930,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,1890,330,1920,330,960,330,930,330,1920,330,960,330,960,330,960,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,960,330,930,330,1920,330,930,330,960,300,930,330,930,330,960,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,1920,330,1920,330,3900,300,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,930,330,1920,330,930,330,960,330,930,330,960,330,930,330,960,330,960,300,1920,330,1920,330,930,330,930,330,960,330,1920,330,1920,330,1920,300,1920,330,960,330,960,330,1920,330,960,330,930,330,930,330,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,930,330,930,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330,960,330,930,330,930,330,930,330,930,330,930,330,1920,330,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,2160,330,930,330,960,330,1920,330,930,330,960,330,960,300,1920,330,1920,330,3870,330,1920,330,930,330,930,330,1920,330,960,330,930,300,1920,330,1920,330,1920,330,930,330,930,330,1920,330,960,330,930,330,960,330,930,330,930,330,930,330,930,330,1920,300,1920,330,930,330,930,330,930,330,1920,330,1920,330,1920,330,1920,330,930,330,960,330,1920,330,930,330;
20;77;Tunex;ID=9302;TEMP=0018;HUM=35;BAT=OK;
xztraz
Re: WH1285 TX (WH-5) Temp & Humidity sensor
#8 Post by xztraz » 22 Jan 2017, 11:50
Tested humidity. after breathing on it it shows 48% and 28,9C
Now put in a location where i have another humidity reader to compare.
How do you determine the battery level/OK btw?
xztraz
Re: WH1285 TX (WH-5) Temp & Humidity sensor - Soon Supported!
#9 Post by xztraz » 22 Jan 2017, 16:53
After some testing i see that the humidity value fluctuates quite much. And the temp somtimes.
Humidity in measured room should be around 60%(accoding to dehumidifier) sesor reading shows a bit under that but hard to tell when it fluctuates whats an accurate reading.
Tested temp in the freezer. Shows -16c seem correct at negative temps.
Shall also try outside where himidity should be close too 100% today
DateTime,Humidity,DateTime,Temperature
2017-01-22 11:20:00,23,2017-01-22 11:20:00,22.5
2017-01-22 11:25:00,23,2017-01-22 11:25:00,22.5
2017-01-22 11:30:00,23,2017-01-22 11:30:00,22.5
2017-01-22 11:35:00,23,2017-01-22 11:35:00,22.6
2017-01-22 11:40:00,23,2017-01-22 11:40:00,22.6
2017-01-22 11:45:00,22,2017-01-22 11:45:00,22.5
2017-01-22 11:50:00,54,2017-01-22 11:50:00,27.7
2017-01-22 11:55:00,5,2017-01-22 11:55:00,23.8
2017-01-22 12:00:00,5,2017-01-22 12:00:00,19.2
2017-01-22 12:05:00,4,2017-01-22 12:05:00,13.6
2017-01-22 12:10:00,4,2017-01-22 12:10:00,11.8
2017-01-22 12:15:00,48,2017-01-22 12:15:00,10.9
2017-01-22 12:20:00,3,2017-01-22 12:20:00,10.2
2017-01-22 12:25:00,3,2017-01-22 12:25:00,10
2017-01-22 12:30:00,39,2017-01-22 12:30:00,10.1
2017-01-22 12:35:00,37,2017-01-22 12:35:00,10.2
2017-01-22 12:40:00,38,2017-01-22 12:40:00,10
2017-01-22 12:45:00,3,2017-01-22 12:45:00,9.6
2017-01-22 12:50:00,3,2017-01-22 12:50:00,9.7
2017-01-22 12:55:00,39,2017-01-22 12:55:00,9.9
2017-01-22 13:00:00,37,2017-01-22 13:00:00,10
2017-01-22 13:05:00,38,2017-01-22 13:05:00,9.8
2017-01-22 13:10:00,3,2017-01-22 13:10:00,9.6
2017-01-22 13:15:00,3,2017-01-22 13:15:00,9.7
2017-01-22 13:20:00,39,2017-01-22 13:20:00,9.9
2017-01-22 13:25:00,37,2017-01-22 13:25:00,9.9
2017-01-22 13:30:00,37,2017-01-22 13:30:00,9.7
2017-01-22 13:35:00,3,2017-01-22 13:35:00,9.5
2017-01-22 13:40:00,3,2017-01-22 13:40:00,9.6
2017-01-22 13:45:00,56,2017-01-22 13:45:00,49.8
2017-01-22 13:50:00,37,2017-01-22 13:50:00,10
2017-01-22 13:55:00,38,2017-01-22 13:55:00,9.8
2017-01-22 14:00:00,59,2017-01-22 14:00:00,49.5
2017-01-22 14:05:00,3,2017-01-22 14:05:00,9.7
2017-01-22 14:10:00,38,2017-01-22 14:10:00,9.9
2017-01-22 14:15:00,37,2017-01-22 14:15:00,10
2017-01-22 14:20:00,38,2017-01-22 14:20:00,9.8
2017-01-22 14:25:00,3,2017-01-22 14:25:00,9.5
2017-01-22 14:30:00,3,2017-01-22 14:30:00,9.7
2017-01-22 14:35:00,38,2017-01-22 14:35:00,9.9
2017-01-22 14:40:00,37,2017-01-22 14:40:00,10
2017-01-22 14:45:00,38,2017-01-22 14:45:00,9.7
2017-01-22 14:50:00,3,2017-01-22 14:50:00,9.6
2017-01-22 14:55:00,3,2017-01-22 14:55:00,9.8
2017-01-22 15:00:00,38,2017-01-22 15:00:00,9.9
2017-01-22 15:05:00,36,2017-01-22 15:05:00,10
2017-01-22 15:10:00,38,2017-01-22 15:10:00,9.8
2017-01-22 15:15:00,3,2017-01-22 15:15:00,9.6
2017-01-22 15:20:00,3,2017-01-22 15:20:00,9.8
2017-01-22 15:25:00,37,2017-01-22 15:25:00,10
2017-01-22 15:30:00,36,2017-01-22 15:30:00,9.9
2017-01-22 15:35:00,39,2017-01-22 15:35:00,9.7
2017-01-22 15:40:00,3,2017-01-22 15:40:00,9.7
2017-01-22 15:45:00,39,2017-01-22 15:45:00,9.8
2017-01-22 15:50:00,37,2017-01-22 15:50:00,9.9
2017-01-22 15:55:00,36,2017-01-22 15:55:00,9.9
2017-01-22 16:00:00,39,2017-01-22 16:00:00,9.7
2017-01-22 16:05:00,3,2017-01-22 16:05:00,9.7
2017-01-22 16:10:00,39,2017-01-22 16:10:00,9.8
2017-01-22 16:15:00,38,2017-01-22 16:15:00,9.9
2017-01-22 16:20:00,36,2017-01-22 16:20:00,9.9
2017-01-22 16:25:00,3,2017-01-22 16:25:00,9.6
2017-01-22 16:30:00,3,2017-01-22 16:30:00,9.6
2017-01-22 16:35:00,39,2017-01-22 16:35:00,9.8
2017-01-22 16:40:00,37,2017-01-22 16:40:00,9.9
2017-01-22 16:45:00,37,2017-01-22 16:45:00,9.9
2017-01-22 16:50:00,3,2017-01-22 16:50:00,9.6
any idea. do you check the crc?
best regards
xztraz
Re: WH1285 TX (WH-5) Temp & Humidity sensor - reads as alectrov3 sometimes
#10 Post by xztraz » 22 Jan 2017, 18:06
I think i found the problem.
Seem like the sensor sometimes are read as an alectrov3 and sometimes an fine offset.
Log from RfLink
20;07;AlectoV3;ID=00ea;TEMP=8036;HUM=3c;BAT=OK;
20;09;AlectoV3;ID=00ea;TEMP=8005;HUM=46;BAT=OK;
20;11;FineOffset;ID=00ea;TEMP=01a2;HUM=78;
20;15;FineOffset;ID=00ea;TEMP=0182;HUM=75;
20;17;AlectoV3;ID=00ea;TEMP=802e;HUM=47;BAT=OK;
20;1B;FineOffset;ID=00ea;TEMP=0149;HUM=65;
20;1F;FineOffset;ID=00ea;TEMP=0133;HUM=61;
20;23;FineOffset;ID=00ea;TEMP=0123;HUM=60;
20;25;AlectoV3;ID=00ea;TEMP=8054;HUM=3d;BAT=OK;
20;27;AlectoV3;ID=00ea;TEMP=801d;HUM=44;BAT=OK;
20;29;AlectoV3;ID=00ea;TEMP=0013;HUM=4d;BAT=OK;
Restarted sensor for new adress just to check for collisions
20;32;AlectoV3;ID=00c7;TEMP=00aa;HUM=5a;BAT=OK;
20;33;AlectoV3;ID=00c7;TEMP=00b5;HUM=58;BAT=OK;
20;35;AlectoV3;ID=00c7;TEMP=00bd;HUM=54;BAT=OK;
20;37;FineOffset;ID=00c7;TEMP=0254;HUM=79;
Same behavior
xztraz
Re: WH1285 TX (WH-5) Temp & Humidity sensor - Temp ok, hum still needs some work
#11 Post by xztraz » 22 Jan 2017, 20:30
Captured some more debug data:
put meter in freezer -10 at least
Sensor output in domoticz
When found/read as alectro v3
*Temp reads fine + and -
*Humidity is flunked, reads to low and jumps around
When found/read as Fine Offset
*Temp is flunked - reads ~40C to high, + is ok but i've seen wierd stuff under 20c too.. maybe it depends on if one extra preamble bit or one less. and the signed bit. what do i know :)
*Humidity seem to be quite close to reality but jumps around in domoticz.
so ignore earlier posts with temperature tests since they where done with domotics thinking it was an alectrov3
Seem like when the data shifts one bit around and when shifted it reads as fineoffset. otherwise(mostly) reads as alectrav3
when it misses one bit or get one extra of preamble it reads fine (offset)
since the alectra seem to have a battery reading. maybe they can be separated on that. maybe message is longer for alectrav3?
10;version;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;08;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,6990;
13
20;09;AlectoV3;ID=00cc;TEMP=807a;HUM=23;BAT=OK;
20;0D;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,6990;
13
20;0E;AlectoV3;ID=00cc;TEMP=8087;HUM=22;BAT=OK;
20;0F;DEBUG;Pulses=96;Pulses(uSec)=390,570,390,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
80
20;10;FineOffset;ID=00cc;TEMP=00ff;HUM=34;
20;13;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,900,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,900,1350,870,1380,870,390,870,390,870,1350,900,1350,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1350,870,390,870,390,870,390,870,1380,870,1350,870,390,870,1380,870,1350,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1350,870,1380,6990;
80
20;14;FineOffset;ID=00cc;TEMP=00f7;HUM=33;
20;17;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,6990;
13
20;18;AlectoV3;ID=00cc;TEMP=809f;HUM=21;BAT=OK;
20;24;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1350,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1350,870,390,6990;
13
20;25;AlectoV3;ID=00cc;TEMP=80a2;HUM=21;BAT=OK;
20;2E;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,900,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1350,870,1380,870,390,870,390,870,1350,900,1350,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,900,390,870,390,870,390,870,1380,870,1350,870,390,870,1380,870,1350,870,1380,870,1350,870,390,870,390,870,1350,870,1380,870,1350,870,390,870,390,870,1350,870,390,6990;
80
20;2F;FineOffset;ID=00cc;TEMP=00ef;HUM=33;
20;3A;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,6990;
13
20;3B;AlectoV3;ID=00cc;TEMP=80a0;HUM=21;BAT=OK;
20;4E;DEBUG;Pulses=92;Pulses(uSec)=480,870,390,900,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,1350,870,390,870,390,870,390,870,390,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1350,900,1350,870,1380,870,1350,870,390,870,390,900,1350,870,390,870,1350,870,1380,870,1380,870,390,870,390,6990;
80
20;4F;FineOffset;ID=00cc;TEMP=00f2;HUM=33;
20;55;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,6990;
13
20;56;AlectoV3;ID=00cc;TEMP=809b;HUM=21;BAT=OK;
20;6D;DEBUG;Pulses=94;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,6990;
13
20;6E;AlectoV3;ID=00cc;TEMP=8096;HUM=21;BAT=OK;
20;77;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,390,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,1350,870,1380,870,1350,870,1380,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,390,870,1350,6990;
80
20;78;FineOffset;ID=00cc;TEMP=00fd;HUM=33;
20;85;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,900,1350,870,1380,870,390,870,390,870,1350,900,1350,870,390,870,390,870,1380,870,1350,870,1380,870,1380,870,1350,870,390,870,1350,900,1350,870,1380,870,1350,870,1380,870,1380,870,1350,870,1380,870,1350,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,870,390,870,1350,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1350,6990;
80
20;86;FineOffset;ID=00cc;TEMP=0100;HUM=33;
20;91;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,900,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,1350,900,390,870,1380,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,1380,870,390,900,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,6990;
80
20;92;FineOffset;ID=00cc;TEMP=0102;HUM=33;
20;95;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,900,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,390,900,390,870,1380,870,1350,870,1380,870,1380,870,1350,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,390,870,1380,870,390,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,1350,870,1380,870,1380,870,1350,6990;
80
20;96;FineOffset;ID=00cc;TEMP=0105;HUM=34;
20;A7;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,900,390,870,1380,870,390,870,1380,870,1350,900,390,870,390,870,1350,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,1350,870,1380,870,390,870,1350,870,1380,870,1350,900,1350,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1350,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,870,1380,870,1350,6990;
80
20;A8;FineOffset;ID=00cc;TEMP=0108;HUM=34;
20;B4;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,870,1350,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,1350,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,870,390,870,1350,870,390,870,1350,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,6990;
80
20;B5;FineOffset;ID=00cc;TEMP=010a;HUM=33;
20;C8;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1350,870,390,870,390,900,1350,870,1380,870,390,870,390,870,1350,900,1350,870,1380,870,1350,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,870,390,870,390,870,1380,870,1350,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,390,870,1350,870,1380,870,1350,870,1380,6990;
80
20;C9;FineOffset;ID=00cc;TEMP=010c;HUM=33;
20;D4;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,6990;
13
20;D5;AlectoV3;ID=00cc;TEMP=8081;HUM=22;BAT=OK;
20;DF;DEBUG;Pulses=92;Pulses(uSec)=480,870,390,870,390,900,390,870,390,870,390,870,1350,900,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,1350,900,1350,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,1350,870,1380,870,390,900,1350,870,390,870,390,870,390,870,1350,870,390,870,390,870,1350,870,390,6990;
80
20;E0;FineOffset;ID=00cc;TEMP=0111;HUM=34;
20;F3;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,6990;
13
20;F4;AlectoV3;ID=00cc;TEMP=807d;HUM=22;BAT=OK;
20;00;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,6990;
13
20;01;AlectoV3;ID=00cc;TEMP=807a;HUM=23;BAT=OK;
20;0B;DEBUG;Pulses=94;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,6990;
13
20;0C;AlectoV3;ID=00cc;TEMP=8078;HUM=23;BAT=OK;
20;12;DEBUG;Pulses=92;Pulses(uSec)=450,870,390,870,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1350,870,390,870,390,870,1380,870,1380,870,390,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,390,870,1380,870,1380,870,1350,870,390,870,390,870,390,870,1380,870,1350,870,1380,870,1350,870,390,870,1380,870,1350,870,390,870,1350,870,1380,870,1380,870,1350,870,1380,870,1350,870,390,870,1380,870,390,870,390,6990;
80
20;13;FineOffset;ID=00cc;TEMP=011c;HUM=36;
Stuntteam
Site Beheer
Re: WH1285 TX (WH-5) Temp & Humidity sensor - reads mostly as alectrov3 and decodes data as that
#12 Post by Stuntteam » 23 Jan 2017, 00:30
Dont worry about that..
It was another patch for fineoffset that was in your test version.
There were also some other things for testing in there.
xztraz
#13 Post by xztraz » 23 Jan 2017, 07:26
Hehe ok.
Sorry for bombarding you with data. Used to work as a software tester.
This is how the data looks when used as an fine offset in domoticz
temp should be ~10C and humidity ~60%
If you want me to run more test on the sensor/other test versions just give me a shout. ☺
xztraz
Re: Fine offset WH1285 TX (WH-5) Temp & Humidity sensor
#14 Post by xztraz » 27 Jan 2017, 12:56
Testing with 9 sensors now on test version. finds them all.
Stuntteam
Site Beheer
#15 Post by Stuntteam » 27 Jan 2017, 16:24
check your mail..
xztraz
#16 Post by xztraz » 27 Jan 2017, 21:33
Tests with new firmware looks promising. Details in mail.
xztraz
#17 Post by xztraz » 27 Feb 2017, 13:53
Just wanted to say that these sensors now work absolutely fine in test version of firmware (rfl4604_test)
Tested with 9 sensors. read by domoticz
