Please help with plugin for ESP8266
orbitcoms
#1 Post by orbitcoms » 05 Apr 2017, 01:13
I am trying to get access to the thermocouple plugin.
When I look at the devices list in my ESP, I cannot see a thermocouple option available. However, it does appear in the plugin playground.
Maybe I have wrong version of firmware installed? I tried to follow the Arduino examples but could not get code to compile - kept giving "free mem" not found error
The hardware is ESP8266-07 (1MB flash).
Should I be using V1.47 or the new version 2.0 firmware?
Does the bin file have the thermocouple plugin already installed or do I need to compile in Arduino from source first?
If I need to compile in Arduino, is there another step-by-step example of this. I tried Arduino 1.8 and 1.6.5 and 1.6.12(the guide states using this version and not actually recommending using the "latest" version of arduino).
Dave
krikk
Re: Please help with plugin for ESP8266
#2 Post by krikk » 05 Apr 2017, 17:43
guide for compiling 2.0 firmware:
https://www.letscontrolit.com/wiki/inde ... evelopment
https://github.com/letscontrolit/ESPEas ... couple.ino <-- is in the 2.0 firmware...
so if you get the files from here https://github.com/letscontrolit/ESPEas ... 2.0.0-dev7 it should work
jojocardee
#3 Post by jojocardee » 18 Apr 2017, 05:11
sbobet mobile
orbitcoms
#4 Post by orbitcoms » 18 Apr 2017, 05:33
Thanks for your comments, I managed to compile and run the latest Ver 2.0 (Dev 7). I un-commented the "Dev" plugin option and now see all the plugins ok when I configure my device.
Just one other question: I want to use the MAX31856 instead of the MAX31855. This requires a couple of register values to be written at startup. How do I get the plugin to write these values when the device starts?
Can I use "rules"
