Support dust sensor
BertB
Support dust sensor
#1 Post by BertB » 01 Nov 2015, 16:14
As of R041the GP2Y10 Dust sensor is being supported.
I am working on the support of the PPD42 dust sensor, but I am also interested in the performance of the GP2Y10.
Furthermore, I like to know what type of device is chosen in Domoticz?
Ger
Re: Support dust sensor
#2 Post by Ger » 02 Nov 2015, 16:10
I have the sharp GP2Y10 dust sensor still in test, I am waiting for a box to built it in ;)
The following link is someone also using this sensor http://www.pocketmagic.net/sharp-gp2y10-dust-sensor/
In domoticz I use voltage as device.
Ger
#3 Post by Ger » 02 Nov 2015, 16:10
And an other screenprint
BertB
#4 Post by BertB » 02 Nov 2015, 22:52
This is what I get with PPD42 sensor. I use the percentage device in Domoticz.
Ger
#5 Post by Ger » 04 Nov 2015, 22:20
BertB wrote:This is what I get with PPD42 sensor. I use the percentage device in Domoticz.
I have looked up the PPD42 sensor and the PPD42 has more options as the Sharp GP2Y1010 but is also a little bit more expensive.
Do you use the PPD42 sensor with espeasy?
BertB
#6 Post by BertB » 04 Nov 2015, 23:40
Yes I do, but it is still under construction.
bertrand
#7 Post by bertrand » 30 Jun 2016, 18:45
Hi Guys,
Here is Asia, the trend is to laser dust detectors which are way more accurate. They are between 15USD and 40USD.
Nova SDS011
Plantower G1 or G5
http://www.aliexpress.com/wholesale?spm ... aser+pm2.5
They are very stable and accurate:
http://aqicn.org/sensor/
tobia
#8 Post by tobia » 24 Apr 2017, 20:26
Hello, is it possible to support this sensor (NOVA SDS011)?
It is used successfully in the project http://luftdaten.info
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 17 guests
