As of R041the GP2Y10 Dust sensor is being supported.
I am working on the support of the PPD42 dust sensor, but I am also interested in the performance of the GP2Y10.
Furthermore, I like to know what type of device is chosen in Domoticz?
Support dust sensor
Re: Support dust sensor
The following link is someone also using this sensor http://www.pocketmagic.net/sharp-gp2y10-dust-sensor/
In domoticz I use voltage as device.
And an other screenprint
This is what I get with PPD42 sensor. I use the percentage device in Domoticz.
I have looked up the PPD42 sensor and the PPD42 has more options as the Sharp GP2Y1010 but is also a little bit more expensive.BertB wrote:This is what I get with PPD42 sensor. I use the percentage device in Domoticz.
Do you use the PPD42 sensor with espeasy?
Yes I do, but it is still under construction.
Hi Guys,
Here is Asia, the trend is to laser dust detectors which are way more accurate. They are between 15USD and 40USD.
Nova SDS011
Plantower G1 or G5
http://www.aliexpress.com/wholesale?spm ... aser+pm2.5
They are very stable and accurate:
http://aqicn.org/sensor/
Nova SDS011
Plantower G1 or G5
Hello, is it possible to support this sensor (NOVA SDS011)?
It is used successfully in the project http://luftdaten.info
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 11 guests
