I'm using Release v2.0.0-dev10 and trying to configure my INA219 devices but am unable to select the IDX value from Domoticz. ...though I'm pretty sure that this was avalailable in Release v2.0.0-dev08. Consequently, my Domoticz displays are all red for these devices. Please see attached screenshots.
Please advise if I've missed some configuration change or whether this is really a bug.
Please note that even when using Release v2.0.0-dev08 with the IDX settings, Domoticz still couldn't see the device data.
Release v2.0.0-dev10 - Bug? IDX Option gone
- Domoticz cannot see ESPEasy devices.
- Domoticz20170606.jpg (264.25 KiB) Viewed 4820 times
- No longer any field element to add Domoticz IDX value.
- Device4Details_20170606.jpg (48.2 KiB) Viewed 4820 times
RobUpNorth
Re: Release v2.0.0-dev10 - Bug? IDX Option gone
I think in 2.0.10 IDX is removed and changed IDX = TASK.
___________________________
HAM Callsign: KD0NER
As every task number starts with "1" in the ESPEasy firmware
that won't work i think.
It seems it has been replaced with something other...
but i don't know with what... the column still is in the task list.
Plugin INA219 was reworked after release 10. Should be fixed in next release
At least the reworked plugin is not in the sources yet.
Just tested a build from actual sources.
