vincen
#1
Post
by vincen » 10 Jul 2017, 10:16
After having used few NodeMCU V2/V3 with ESP Easy I wanted to test it on D1 Mini Pro. I just received mine and I have a little issue. I did a clean of the flash without problem:
vincen@Fixe-Ubuntu:~/Bureau$ esptool.py --port /dev/ttyUSB0 erase_flash
esptool.py v2.0
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 38.8s
Hard resetting...
Then I flashed the firmware in it also without any troubles:
vincen@Fixe-Ubuntu:~/Bureau$ esptool.py --port /dev/ttyUSB0 write_flash -fm dio 0x00000 ESPEasy_v2.0.0-dev10_dev_8285.bin
esptool.py v2.0
Connecting....
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 16MB
Flash params set to 0x0290
Compressed 583728 bytes to 383495...
Wrote 583728 bytes (383495 compressed) at 0x00000000 in 33.7 seconds (effective 138.5 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting...
Once rebooted I get blue led on board to blink once every 3/4 seconds and that's it ! I have no ESP_0 wifi signal appears !
What can I do to find the problem ? and fix it ?
Vincèn
toffel969
#2
Post
by toffel969 » 10 Jul 2017, 10:22
vincen wrote: ↑10 Jul 2017, 10:16
esptool.py v2.0
Connecting....
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Hard resetting...
esptool.py v2.0
Connecting....
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Leaving...
Hard resetting...
Vincèn
Try to connect with a serial adapter and see what is going on. I had a similiar thing, when connecting with serial I saw numbers running up. After it finished running up, it booted normally and I found the ESP_0.
vincen
#3
Post
by vincen » 10 Jul 2017, 12:58
toffel969 wrote: ↑10 Jul 2017, 10:22Try to connect with a serial adapter and see what is going on. I had a similiar thing, when connecting with serial I saw numbers running up. After it finished running up, it booted normally and I found the ESP_0.
Well I connected with Minicom to the USB port of the D1 and it's stuck in a boot loop
Here is what I get in bootloop ? I'm going to try the other versions avalaible to check if it's the same !
INIT : Booting version: v2.0.0-dev10
FS : Mount failed
FS : Mount failed
PID:0
Version:0
INIT : Incorrect PID or version!
Resetting factory defaults...
RESET: Reboot count: 160
RESET: To many reset attempts
Exception (0):
epc1=0x40106f19 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff35d0 end: 3fff3840 offset: 01a0
>>>stack>>>
3fff3770: 0000001c 00000000 3fff2758 401004d8
3fff3780: 3fff2758 3fff2758 3fff4a7c 40205b69
3fff3790: 00000000 00000001 0000005b 4010020c
3fff37a0: 0000001c 00000000 3fff2758 00000000
3fff37b0: 0000001c 00000000 3fff2758 40201710
3fff37c0: 00000001 3fff3890 3fff2820 3fff3890
3fff37d0: 3fffdad0 3fff2814 40203314 3fff2814
3fff37e0: 3fffdad0 3fff2758 3fff15bc 40216135
3fff37f0: 3fffdad0 3fff2758 3fff15bc 4023342d
3fff3800: feefeffe feefeffe feefeffe 3fff4a8c
papperone
#4
Post
by papperone » 10 Jul 2017, 13:39
D1 Mini PRO has 16Mb and not 4Mb si I suspect the issue is that you need to compile the firmware with the right settings and not to use a precompiled one...
EDIT: why your are flashing an ESP8266 with ESP8285 compiled??
vincen
#5
Post
by vincen » 10 Jul 2017, 15:01
papperone wrote: ↑10 Jul 2017, 13:39D1 Mini PRO has 16Mb and not 4Mb si I suspect the issue is that you need to compile the firmware with the right settings and not to use a precompiled one...
oki my fault, I expected smaller firmware to fit in larger chips no ?
papperone wrote: ↑10 Jul 2017, 13:39EDIT:
I used the precompiled one avalaible on website so going to look now for version for 16M and try to flash it and see how it goes
Update: I installed PlatformIO in my Atom and downloaded source to build a custom one but there is no option to set memory higher than 4Mb
and I found none precompiled for 16M
toffel969
#6
Post
by toffel969 » 12 Jul 2017, 10:50
vincen wrote: ↑10 Jul 2017, 15:01
Your assumption that smaller firmware should fit is correct. I use precomiled *.bin on D1 pro mini, I think the 8285 vs 8266 is the relevant problem here.
LeisureLadi
#7
Post
by LeisureLadi » 25 Jul 2017, 06:55
ESP8285 has 1MB built-in flash memery using DOUT flash mode. Your WEMOS has got external flash memory (either 4 MB or 16 MB, of which only 4 MB can be really used) which needs to be flashed in DIO mode. Size of the precompiled program doesn't matter as reported already.
randytsuch
#8
Post
by randytsuch » 25 Jul 2017, 17:01
I had the same problem, and ended up installing the arduino compiler, and built ESP Easy from source.
There are a lot of tutorials online that describe some changes you need to make for the ESP, mostly adding 4 libraries.
Using the code I built, I was able to get a pro to run, and ESP_0 shows up after a few minutes.
Randy
Users browsing this forum: Ahrefs [Bot] and 13 guests
