ESP12 Wiring check
ESP12 Wiring check
Hello! I am new to ESP8266. Can someone check my basic wiring idea? I want to have posibility to easy flash firmware with programmer and want use deep sleep mode. All with one LiIon battery.
Re: ESP12 Wiring check
basically the circutiry is OK.
Two points should be mentioned:
- Place an additional 100nF capacitor (ceramic type) as close as possible to Vcc and GND of the ESP.
Yes i know you have a 100 nF already from Vcc to GND, but that one should be a close as possible to the HT7333
- The HT7333 is nice, but limited. It can take a absolute maximum of 250 mA. This is near to the power consumption of
the ESP-chip. Adding sensors and such might bring it over limits.
Thanks for your reply... in this project, i want create only temp sensor. Learning project for me. After this, i will go find alternative to HT733 ("smart" extension for old analog 1+n system). This will be ok now?
Looks good for me.
As far as i can see you use a single Lion cell.
This is worth a try but be aware that this might run into problems.
The voltage regulator always has a bit voltage loss - the battery goes down to 3,3V
relative quickly. Subtracting the loss of the regulator you might get below 3,3V for the chip.
Mighht or might not work.
Thinked about this and 2s2p LiIon for better capacity and more voltage will be fine
Instead of HT7333? Like Pololu S7V8F3? But what about stepup/down current draw? Isnt it higher than if I use HT7333? If yes, I can use only 2 parallel than instead of 2s2p
right?
Users browsing this forum: Anthropic Claude Bot [bot] and 20 guests
