Hi guys,
I have a sonoff switch that I have uodated with EaspEasy firmware.
It seems work because when I push the sonoff button, in software the status became 1 and if I re-push the button the status became 0.
I have problem when I connect the Sonoff Switch at my boiler; the voltage is ok, the Sonoff is on and work but when I press the switch button the led boiler is always swtich off.
Sonoff Switch with ESPeasy
Re: Sonoff Switch with ESPeasy
You need to tell the FW what to do when the switch is pushed. See this guide for the Touch:
https://www.letscontrolit.com/wiki/inde ... noff_Touch
We haven't completed a guide for the Sonoff Basic but you get the general idea.
thank you for your support but where must I insert the rule?
are you sure that problem is this? i means....rele seems ok with status 1 and 0 when I push button but seems that circuit remains always open.
But how would the relay know that it should act on the switch? This is not a specific FW for Sonoff but a generic FW for "all" ESP 8266/8285.
Regarding where to put the rule, please study the wiki.
Users browsing this forum: Anthropic Claude Bot [bot] and 17 guests
