BMP280
Milifax
BMP280
#1 Post by Milifax » 30 Jul 2017, 12:36
My setup is a Wemos D1 with a BMP280 sensor attached to it. This reports to Domoticz.
As Domoticz didn't have the BMP280 sensor standard onboard, I requested it. They added it, which is nice.
However, the pressure doesn't get registered right.
They use a standard JSON method, see here http://www.domoticz.com/wiki/Domoticz_A ... Fbarometer
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEMP;BAR;BAR_FOR;ALTITUDE
The above sets the parameters for a Temp+Humidity+Barometer device
    IDX = id of your device (This number can be found in the devices tab in the column "IDX")
    TEMP = Temperature
    BAR = Barometric pressure
    BAR_FOR = Barometer forecast
    ALTITUDE= Not used at the moment, can be 0
Barometer forecast can be one of:
0 = No Info
1 = Sunny
2 = Paryly Cloudy
3 = Cloudy
4 = Rain
Although sending the data to a temp+hum+baro sensor works in Domoticz, with this new type the pressure stays empty.
Does anyone have insight in the JSON send by EspEasy with the BMP280. Or is it adjustable to the standard Domoticz uses?
Thanks in advance
Re: BMP280
#2 Post by grovkillen » 30 Jul 2017, 13:43
You need to create your own JSON since this new Domoticz sensor is not yet updated as such within ESP Easy.
https://www.letscontrolit.com/wiki/inde ... th_own_IDX
Milifax
Re: BMP280
#3 Post by Milifax » 31 Jul 2017, 11:30
grovkillen wrote: 30 Jul 2017, 13:43 You need to create your own JSON since this new Domoticz sensor is not yet updated as such within ESP Easy.
Thanks, that helped me a lot.
My solution:
To make ESPEasy work with Domoticz BMP280 sensor, disable the Send to controller for the specific device and;
add a rule in ESPEasy like the following:
On System#Boot do    //When the ESP boots, do
  timerSet,1,240      //Set Timer 1 for the next event in 240 seconds
On Rules#Timer=1 do
  SendToHTTP,192.168.1.80,8080,/json.htm?type=command&param=udevice&idx=69&nvalue=0&svalue=[Barometer#Temperature];[Barometer#Pressure];BAR_FOR;ALTITUDE
  timerSet,1,240       //Resets the Timer 1 for another 240 seconds
-- Comment: Where Barometer is the name of the device and #Temperature and #Pressure are the valuenames
-- Above will send updates every 4 minutes, hench the timer set
Hope this helps any other users in the future.
Re: BMP280
#4 Post by grovkillen » 31 Jul 2017, 12:06
Glad to hear. Thanks for your report and guide!
Users browsing this forum: Anthropic Claude Bot [bot] and 14 guests
