ESPEasy R120 Rules - [need help]
cracky
#1 Post by cracky » 06 Aug 2017, 19:05
Hello, guys!
I need some help, I got 1 ESP8266-01 with EspEasy R120 and I need to configure some rules with multiple "if-then" condition.
I have the following:
1 x ESP8266-01
2 x relays
1 x touch button
What I need:
- when I press once the touch button, turn relay 1 ON
- when I press second time, turn relay 2 ON
and the third time -> turn off both
What I got now with the rules bellow..
When I press touch button, first relay start on, then relay 2, and after that are both off -> and the cycle repeats until I press again the touch button.
on Touch#Switch do
if [Touch#Switch]=1.00
gpio,1,1
event checkBec1
on checkBec1 do
if [bec1#Switch]=1.00
gpio,2,1
event checkBec2
on checkBec2 do
if [bec2#switch]=1.00
gpio,1,0
gpio,2,0
Help please, I have 0 experience with this coding type.
Thank you in advance!
cracky
Re: ESPEasy R120 Rules - [need help]
#2 Post by cracky » 10 Aug 2017, 18:20
Anyone?:)
#3 Post by grovkillen » 10 Aug 2017, 20:12
Have you studied the wiki? Since the syntax is not correct I believe you haven't. Please read it and then come here if you still need help.
The (rules) tutorial section as well as the guide for Sonoff Touch will give you the answers.
Yann1420@live.co.uk
#4 Post by Yann1420@live.co.uk » 22 Aug 2017, 09:13
Do not misunderstand me, this team has done a great job.
But what I am missing for example is simple things like is the basic syntax rules, e.g. case-sensitive, indentation, line-continuation, keywords.
#5 Post by grovkillen » 22 Aug 2017, 09:43
Regarding line indent, case-sensitive are no problem, but yes - it is not stated in the wiki. Regarding the rule asked for here:
 on touch#switch do
    if [count#state]>1
      TaskValueSet,4,1,0
      TaskValueSet,4,1,[count#state]+1
   on count#state=0 do
    gpio,1,0
    gpio,2,0
  on count#state=1 do
    gpio,1,1
  on count#state=2 do
    gpio,2,1
This uses a dummy device called "count" (task number 4) and dump the current state to value number 1 "state".
cracky
#6 Post by cracky » 04 Sep 2017, 21:31
Hello, guys!
I really appreciate your help, thank you for that, especially grovkillen.
I tried the script you provided with dummy device and after some more settings it works :)
It looks like this:
Devices:
Rules:
 on Touch#Twitch do
      TaskValueSet,4,1,0
    if [count#state]>1
      TaskValueSet,4,1,0
   on count#state=0 do
    gpio,1,1
    gpio,2,1
  on count#state=1 do
    gpio,1,0
  on count#state=2 do
    gpio,2,0
#7 Post by grovkillen » 06 Sep 2017, 04:58
Happy to have helped. Thanks for the update!
cracky
#8 Post by cracky » 10 Sep 2017, 14:02
Hello!
I still have a question, maybe you know how to do it.
In this case if I turn off the light from the button and then I want to start it from the openhab, it runs the rule where it counts the value of the dummy device and does not work.
So I think a way is to set up the dummy device than to set the switch. Is it possible to set a value on dummy device using MQTT :?:
Thank you!
toffel969
#9 Post by toffel969 » 10 Sep 2017, 15:05
cracky wrote: 10 Sep 2017, 14:02 Hello!
Thank you!
No not directly... But you can send an event value. This event value can be written into a dummy device. So there is a workaround .
Check
Check https://www.letscontrolit.com/wiki/inde ... _Variables
Together with wikion dummy
DrJeff
#10 Post by DrJeff » 11 Sep 2017, 17:31
I love those capacitive touch buttons got a bag full of them and they work great behind plastic inside of cases or plates!
:D
cracky
#11 Post by cracky » 12 Sep 2017, 14:34
DrJeff & toffel969- thank you!
Short story: I made it work!
Long stroy:
Let me tell you what the structure of the project is and why I needed these rules :mrgreen:
I use a relay and touch button, ordered by esp8266 01 and I can:
- turn on and off the room light (2 channels) from the touch button (on the wall)
- turn on and off the room light from OpenHab via MQTT
- turn on and off the room light from Amazon Echo (Alexa) via OpenHab via MQTT :)
The problem was: If I turn off the light from the button and then I want to start it from the openhab, it runs the rule where it counts the value of the dummy device and does not work.
How I solved it, by adding a rule for count state and a wrong value for dummy device, to count it 0 after system boot :)
on System#Boot do
  TaskValueSet 4,1,10 // default value at boot
on System#Boot do
gpio,0,0
on System#Boot do
gpio,2,0
 on Touch#value do
    if [count#state]>1
      TaskValueSet,4,1,0
 on Touch#value do
    if [count#state]=0 do
    gpio,0,0
    gpio,2,0
 on Touch#value do
    if [count#state]=1 do
    gpio,0,1
 on Touch#value do
    if [count#state]=2 do
    gpio,2,1
Thank you guys!
Users browsing this forum: Ahrefs [Bot] and 18 guests
