Rules Event On and OFF
freijn
#1 Post by freijn » 02 Jul 2017, 11:39
Guys,
I am stuck in my rules and do not understand where I am going wrong :-(
From the page :
https://www.letscontrolit.com/wiki/inde ... ith_events
I have copied the full script and started to modify it a little.
Now the issue I am facing that I can start the event, but can not stop it #$%#$%@$#
I can start it with:
http://192.168.1.19/control?cmd=event,vuurtorenaan
But stop does not work:
http://192.168.1.19/control?cmd=event,vuurtorenuit
As you can see I have put an LED on GPIO 13. The led goes on and off per url request to go on and off. So the even on/off works.
I guess the issue is in the "timerSet,1,0" on the stop event. But as you can see the code is copied from the example page.......
Please advise or hint me in the correct direction ?
Goal :
To be able with a URL into ESP_EASY to start and stop a PWM slow on and off signal simulation a lighthouse light.
Many thanks for your time/help
Frank
This is my rules code :
//start the warning signal when we receive a start_warning event:
On vuurtorenaan do
timerSet,1,1
gpio,13,1
//stop the warning signal when we receive a stop_warning event:
On vuurtorenuit do
timerSet,1,0
gpio,13,0
//create an actual warning signal, every time timer 1 expires:
On Rules#Timer=1 do
//repeat after 2 seconds
timerSet,1,0.5
//pulse some led on pin 4 shortly
PWM,13,1024,1000
gpio,16,1
//Pulse,14,1,500
//produce a short 1000hz beep via a piezo element on pin 14
PWM,13,0,1000
gpio,16,0
Re: Rules Event On and OFF
#2 Post by grovkillen » 02 Jul 2017, 12:47
On vuurtorenuit do
timerSet,1,0
gpio,13,0
That part should be
On vuurtorenuit do
gpio,13,0
timerSet,1,0
Since the "timerSet,1,0" will make the if break out the "On Rules#Timer=1 do" and never trigger "gpio,13,0".
Hope it helps
Martinus
#3 Post by Martinus » 02 Jul 2017, 14:03
You should not mix gpio and pwm commands to the same pin (because it does not handle well).
If pwm has been used on a pin, the gpio commands have no effect until you set pwm to value 0 before using gpio commands again...
freijn
#4 Post by freijn » 02 Jul 2017, 19:51
Guys
Thanks for the quick reply.
I cleaned up my test code/rules. And stil having the same issue..
Can start with :
Can not stop with :
Would you be so kind to look after it again and advise me why my "vuurtorenuit" event does not stop the cyclus ?
My code
//start the signal when we receive a vuurtorenaan event:
On vuurtorenaan do
timerSet,1,1
//stop the signal when we receive a vuurtorenuit event:
On vuurtorenuit
timerSet,1,0
On Rules#Timer=1 do
//fade on led
PWM,13,1024,1000
//fade off led
PWM,13,0,1000
//repeat after 1 seconds
timerSet,1,1
freijn
#5 Post by freijn » 02 Jul 2017, 21:10
Hemmmmmmm
The below code does go on and off with the event on and off url
Only difference I see is that the timer is set to 600 instead of 1 sec.
Any hints ?
On startw do
gpio,13,1 //start watering (open valve)
timerSet,1,600 //timer 1 set for 10 minutes
On stopw do
timerSet,1,0 //timer 1 set to halt, used to stop watering before the timer ends!
On Rules#Timer=1 do
gpio,13,0 //stop watering (close valve)
endOn
#6 Post by grovkillen » 02 Jul 2017, 21:41
Yes, 1 second might be a bit fast and possibly is casing the timer to miss the trigger. We need to make a small passus about short time when using timer (on the wiki).
Ernst
#7 Post by Ernst » 11 Aug 2017, 14:03
Hallo Freijn
Maybe a litle too late.
I think why it doesn't switch off is because of your PWM delays.
An ESP is a single threat processor.
While it is busy with PWM delay it cannot receive/handle other actions.
i didn't try but i had a same sort of issue.
Succes.
Gr Ernst
PS Wat voor soort vuurtoren schakel je aan en uit? :roll:
freijn
#8 Post by freijn » 11 Aug 2017, 14:10
Hi Ernst,
I will test your suggestion, many thanks !
If I send a reboot, it does switch off after all :-)
The lighthouse is a plastic tower little over 1 meter hight. I have put an 12v super power led in it. Officially not dimmable but in a short span it does emulate the
lighthouse light effect of a light doing circles in the top of the tower.
Will let you know the results,
Frank
freijn
#9 Post by freijn » 18 Aug 2017, 23:31
Ernst
I have made this one. Brute force hack, but it works :-) (mind the reboot )
On start_warning do
timerSet,1,2
On stop_warning do
reboot
On Rules#Timer=1 do
timerSet,1,2
Pwm,13,1024,800
pwm,13,0,800
delay 300
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 16 guests
