ESP Easy development status
Re: ESP Easy development status
Change requests should perhaps go on the issue tracker on github. (https://github.com/letscontrolit/ESPEasy/issues)
Support requests and discussion should stay on the forum.
Ok i just finshed a lot of tutorials, explaining everything about platformio and github.
They are at the bottom of this page: http://www.letscontrolit.com/wiki/index ... evelopment
great tutorials, would have saved me a few hours if they where published a few days earlyer
@psy0rz
Great tutorial, works out fine, until you write about Smart Code Linter. Perhaps I installed it without knowing what I was doing.
May be this has nothing to do with my current problem, which is that nothing happens (well, Atom seizes to respond) after:
Building the correct version
Press F7 and you will get an overview of possible versions you can build:
I am working on a 64 bit windows 7 pc and could use some help.
smart code linter does not work because we are useing .ino files, it's in the FAQ of platformio... really annoying
@krikk
Okay .. so I removed github and atom completley from my pc and walked through the setup procedures again.
With Linter disabled and Clang (is that safe?) for a later remind.
Still the same problem. When I press F7, i get a pop-up saying that the editor is not reponding ...
did you also remove all user directories after uninstall, so that you really start on a fresh base.
http://docs.platformio.org/en/latest/id ... formio-ide <-- uninstall instructions...
if this does not help, sorry i am also new to platformio
Yas, I did.krikk wrote: ↑06 Mar 2017, 19:09 did you also remove all user directories after uninstall, so that you really start on a fresh base.
if this does not help, sorry i am also new to platformio![]()
You have no problems here?
I am a step further, I had to choose a board and now the editor starts but I do not get the options.krikk wrote: ↑06 Mar 2017, 19:09 did you also remove all user directories after uninstall, so that you really start on a fresh base.
This is what I get
Somehow I managed to get the choice to select the Wemos D1 mini, but now Atom says it cannot compile because there is nothing in the .../ESPEasy/src folderBertB wrote: ↑06 Mar 2017, 20:15I am a step further, I had to choose a board and now the editor starts but I do not get the options.krikk wrote: ↑06 Mar 2017, 19:09 did you also remove all user directories after uninstall, so that you really start on a fresh base.
This is what I get
Did you open the ESPEasy folder in Atom, or did you open the src folder directly? (you should open the ESPEasy folder)BertB wrote: ↑06 Mar 2017, 23:08Somehow I managed to get the choice to select the Wemos D1 mini, but now Atom says it cannot compile because there is nothing in the .../ESPEasy/src folderBertB wrote: ↑06 Mar 2017, 20:15I am a step further, I had to choose a board and now the editor starts but I do not get the options.krikk wrote: ↑06 Mar 2017, 19:09 did you also remove all user directories after uninstall, so that you really start on a fresh base.
This is what I get
Hi. Thanks for the reponse. I am desperately trying to get things up and running, cause I have a lot of ideas, however this kind of programming techniques, I am not familiar with. So please forgive me for asking many stupid questions.
Before I first managed to get any reponse to the F7 keystroke, I had to choose a board with the initialize or update button.
My working folder is /Documents/ESPEasy. In it are:
.git
.pioenvs
lib (with only readme.txt)
MiniProExtender
src (with some files starting with a . (dot)
and a lot of 'normal' ESPEasy stuff.
Then, after selecting ESPEasy.ino and the proper board and pressing F7, I got:
[03/07/17 14:41:34] Processing d1_mini (platform: espressif8266, board: d1_mini, framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
Collected 23 compatible libraries
Looking for dependencies...
Project does not have dependencies
Error: Nothing to build. Please put your source code files to 'C:\Users\Bert\Documents\ESPEasy\src' folder
[ERROR] Took 1.50 seconds
Environment d1_mini [ERROR]
[SUMMARY]
Environment nodemcuv2 [SKIP]
Environment esp12e [SKIP]
Environment nanoatmega328 [SKIP]
So, I moved the 'normal'ESPEasy files to the src folder.
Then, after pressing F7 again:
[03/07/17 14:44:44] Processing d1_mini (platform: espressif8266, board: d1_mini, framework: arduino)
Converting ESPEasy.ino
Library Dependency Graph
|-- <Servo(esp8266)> v1.0.2
|-- <Wire> v1.0
|-- <ESP8266WiFi> v1.0
|-- <ESP8266WebServer> v1.0
Compiling .pioenvs\d1_mini\src\ESPEasy.ino.o
Archiving .pioenvs\d1_mini\libFrameworkArduinoVariant.a
Compiling .pioenvs\d1_mini\FrameworkArduino\Esp.o
Compiling .pioenvs\d1_mini\FrameworkArduino\FS.o
C:/Users/Bert/Documents/ESPEasy/src/ESPEasy.ino:157:26: fatal error: PubSubClient.h: No such file or directory
#include <PubSubClient.h>
compilation terminated.
Compiling .pioenvs\d1_mini\FrameworkArduino\HardwareSerial.o
*** [.pioenvs\d1_mini\src\ESPEasy.ino.o] Error 1
[SUMMARY]
[ERROR] Took 3.48 seconds
.git
.pioenvs
MiniProExtender
[SUMMARY]
|-- <Wire> v1.0
[SUMMARY]
After that, I copied al the downloaded library files to the lib folder.
After hitting F7 again, I got:
[03/07/17 14:50:16] Processing d1_mini (platform: espressif8266, board: d1_mini, framework: arduino)
Collected 44 compatible libraries
|-- <Wire> v1.0
|-- <IRremoteESP8266>
|-- <PubSubClient> v2.6
|-- <Json> v5.6.4
| |-- <ESP8266wifi-master>
|-- <LiquidCrystal_I2C>
| |-- <Wire> v1.0
In file included from C:/Users/Bert/Documents/ESPEasy/src/ESPEasy.ino:153:0:
lib\ESP8266wifi-master/ESP8266WiFi.h:23:26: fatal error: avr/pgmspace.h: No such file or directory
#include <avr/pgmspace.h>
[SUMMARY]
[ERROR] Took 4.46 seconds
|-- <Wire> v1.0
|-- <Json> v5.6.4
| |-- <Wire> v1.0
[SUMMARY]
By the way,
I do not get your list after hitting F7, but this:
Then something went wrong. You shouldn't need to initialize. (initializing creates or updates your platformio.ini, but we've already created a platformio.ini for you with all the nice options you should see in the F7 list)
Can you remove the ESPEasy directory completely, clone again with Github desktop, and then open it again with Atom and press F7.
If it hangs again when you pressed F7, wait a while (30 seconds or so) and then an error will pop up. Please create a screenshot of that.
Edwin
I did as you suggested.
This is the result.
This is the result.
In the meanwhile i also fixed building in Arduino IDE again and updated the wiki.
Use at least v2.0.0-dev7 and the changes i made here: https://www.letscontrolit.com/wiki/inde ... are_Upload
Hi, and thanks for all the good work! I really like ESPeasy and have it on several nodemcu modules. I'm now trying to install it on a Sonoff switch.
I'm running Windows 10 and most of my experience is with the Arduino IDE rather than platformio.
A couple of questions about the Arduino IDE tutorial, as it applies on windows 10 ...
- Is it a specific intention to use Arduino IDE v. 1.6.12? When I followed the link to the main software page, it shows 1.8.1 as the current version. I decided to go ahead with that one (I used the Windows installer option). It wanted to uninstall my previous version so I said yes to that.
- It then installed the IDE in c:\Program files (x86) in a folder named simply Arduino. I'm unsure if this is the folder to rename with P230 at the end and create the folder named Portable, or is it somewhere else?
Please could you clarify a bit? Thanks in advance.
Andrew.
Andrew.
Well, i'm not an expert and running Win7 but i'll try to answer your questions as good as possible.AndrewJ wrote: ↑19 Mar 2017, 18:33 Hi, and thanks for all the good work! I really like ESPeasy and have it on several nodemcu modules. I'm now trying to install it on a Sonoff switch.
Andrew.
At first: If you do a installer based installation you might run into problems when compiling old ESP-Sources (R14x)
or possibly sketches for other platforms - the configurations conflict, even if you make a second "portable" installation.
I've removed all stadard installations and made two independend portable installations, it works.
If you use the win-installer, the Arduino IDE is registered with windows - do not rename the "Arduino" folder, as this will cross the registering.
A regular installation with installer is not portable, the HowTo was written with a portable installation in mind.
i suppose you don't need a "portable" folder with that.
Install the ESP8266 Boards as described in the HowTo.
Download the source zip if you didn't already.
Unpack it to a folder of your choice on your harddisk.
Cupy the libs fromt he source to the "c:\programs(x86)\arduino\libraries" folder.
Rename the "src" folder to "ESPEasy" (Watch capitals!)
Start the IDE and open the "ESPEasy.ino" file.
Scroll down in the source code and make a choice which plugin set should be installed:
/build all the normal stable plugins
//#define PLUGIN_BUILD_NORMAL
//build all plugins that are in test stadium
#define PLUGIN_BUILD_TESTING
//build all plugins that still are being developed and are broken or incomplete
//#define PLUGIN_BUILD_DEV
Select your board or ESP-Type with the IDE's board manager.
Set the SPIFFS size as described in the HowTo (1 MB for the NodeMCU with ESP12E)
Now you may start compilation.
Use the "Ctrl + Alt + S" (export compiled binary) to create a bin file.
The .bin file is created in the same folder the ESPEasy.ino is located.
Due to my experience flashing with the Arduino IDE results in failing boot of the ESP.
I've used the esptool from the source files successfully.
Anyways, this discussion should be moved to the ESPMega board of the forum as it is not staff related.
Hope that helps.
Thanks for the clear and comprehensive reply. Now I get it, I should have downloaded the zip file (not used the Windows Installer!).
Tried it the way you said and it's working, compiled and uploaded to my Sonoff Switch.
Thank you!
(and sorry for posting on the wrong board)
Andrew
Thank you!
Andrew
I have gone through the setup all over again and now I see the fault is maybe somewhere in my interaction with Github.psy0rz wrote: ↑15 Mar 2017, 01:53 In the meanwhile i also fixed building in Arduino IDE again and updated the wiki.
When I am at letscontrolit/ESPEasy, I see: And after Fork:
I think the Forking is not actually been done.
the file structure looks like the naster branch, although github says mega-branch for some reason.
github should always fork all the branches i assume.
Okay ... so I went kamikaze and deleted my repository.
After that, I forked ESPEasy again and now things start to work.
@psyOrz
I thougt I understood how to work with github, but it seems I am still lost.
I managed to make my own fork of the letscontrolit repository and I was successful to compile it using github desktop and Atom.
Now I see there has been some changes, but when I click the Fork button they are not copied to my repository.
Is that normal?
Is that normal?
How can I update my forked repository with the changes made in the letscontrolit/ESPEasy repository?
I'm not sure how to do it with git desktop. (but its possible)
I usually use the commandline and do something like git pull or git pull origin mega.
There is probably some help on github.com on how to do it with git desktop. If you find out how we should update the wiki.
After running R148 for months, i decided to just take a go with the latest github release and take it into production use. All unit's could be upgraded using OTA without a single glitch.
Did not have to dismount a single unit...
Yes of course, i had to reconfigure all unit's from scratch because the mega version uses a different config format, but it took less than 30 minutes to do so for all unit's.
Seem to run fine after two days: Although i'm no longer responsible for lead development, i would suggest to all developers/contributors to 'pause' new features for a while and focus on round-up of the current edition to replace the old R120. What do you think?
+1 for that. Just fix the issues relating none working features. We need all the things working at R120 to still work for 2.0.0.
I agree, we should focus on fixing bugs the coming month so we can move on and finally release a beta of v2.0.
Having all all the devs help with the awesome new features is like giving free candy to a kid. Its just too good not to take.
jkdesign, krikk, can you put the new features on hold for a while, so we dont get merge conflicts on long standing pull requests? ill try to focus on bugfixing the coming weeks. (had a few busy last weeks so i didnt have enough time to make good progress)
Martinus, let us know how stable it runs on all your gadgets
+1 for that
On long term it will be necessary to come to a development scheme similiar to the way the linux kernel is developed.
A very raw layout might be:
1. Collecting - gathering new features for the next release.
2. Freezing, coding and testing. The list of new features is closed, coding and testing.
3. Beta, release candidate...
4. Release of a new version.
At the moment steps 1...3 are done same time.
Following my experience that will not work for unlimited time without issues.
its more like we kept hanging too long at step 1. but im new here and it takes a few months to get "settled" in a new project an community, so to speak
now its time for step 2 indeed.
Did somebody fix the following reported bug?
https://www.letscontrolit.com/forum/vie ... f=6&t=3126
Thanks and best regards,
Chris
Chris
And break the development in two: core/non-core with each having it's own focus / development cycle. Focus of core part should be stability and not new features, while the non-core part (sensors) can focus on new features relying on the core for stability...
+1 here too.
I am running the latest build (-dev10) on two devices and -dev8 on 8 others for a month now. Works like a charm.
I think that the only right way is to split the project between stable and unstable. The stable versions will only get bugfixes (and maybe new features that have really been proven solid)
They could also be labeled Production and Experimental.
Martinus,
The common way to do this is with branches: As soon as we have a stable 2.0 release we should create a 2.0-branch. This will be the production branch in which we only commit the bugfixes, and create versions 2.0.1, 2.0.2 etc.
Development can then continue in the "development" branch, until we decide its time for a 2.1.0 release. (which at that point also will become a bugfix branch, and perhaps we can then make 2.0.x obsolete)
This will make porting bugfixes between the development and production versions much easier, because we can let git do most of the work.
Currently our development branch is "mega", but perhaps its better to switch this back to "master" at some point, since this is also more common.
Sounds good?
Sounds good?
Sounds good. I'm cleaning up the current issue list, moved some stuff from bug to enhancement and added the 2.1.0 milestone.psy0rz wrote: ↑12 Jun 2017, 14:49 Martinus,
Sounds good?
It's time to focus on bugs with the 2.0.0. milestone and get a beta version out...
(if we leave more room for enhancement in 2.0.0. we just never get there anyway...)
So we now have to decide on untagged issues if we can tackle those in 2.0.0. or the 2.1.0 milestone.
Yeah i saw you've been busy. Very nice.
So far, if i tagged it with 2.0.0 it meant i really wanted it to be fixed before that version can be released. These are probably only bugs that are fixable without adding a lot of new code.
Stuff that is not tagged with a mile stone is "to be decided"/"dont know"/"didnt read yet". We probably should scan all the issues to make sure we tagged everything that needs to be tagged for 2.0.0.
Maybe we should make a habbit of tagging ALL issues with a milestone? Perhaps we should create a special "other" milstone for stuff we dont know what to do with, or stuff that doesnt belong to a milestone. (like wiki documentation in some cases)
I wish we could have status of how many user there's out there but one indication is the number of stars on github. We have reached 500+ now over the weekend and if I remember correctly we have risen from 400 stars in just about a month. Great!
https://github.com/letscontrolit/ESPEasy/stargazers
I'm not surprised, i have looked long and hard to find anything simular to ESPEasy (8266 + wifi) and so far i haven't found it.It's like a HA Server for IOT devices and in that sense it's unique AND the first...grovkillen wrote: ↑06 Aug 2017, 11:24 I wish we could have status of how many user there's out there but one indication is the number of stars on github. We have reached 500+ now over the weekend and if I remember correctly we have risen from 400 stars in just about a month. Great!
Yes, your point is probably a good reason of the popularity. Thanks!
+1 to that. Before esp easy my homes automation plans always remained dreams. With esp easy it's a matter of few hours to build, implement and debug a node. Awesome!LisaM wrote: ↑06 Aug 2017, 11:51I'm not surprised, i have looked long and hard to find anything simular to ESPEasy (8266 + wifi) and so far i haven't found it.It's like a HA Server for IOT devices and in that sense it's unique AND the first...grovkillen wrote: ↑06 Aug 2017, 11:24 I wish we could have status of how many user there's out there but one indication is the number of stars on github. We have reached 500+ now over the weekend and if I remember correctly we have risen from 400 stars in just about a month. Great!
+2. Although I'm not as fast, takes me more than a few hours loltoffel969 wrote: ↑09 Aug 2017, 18:17+1 to that. Before esp easy my homes automation plans always remained dreams. With esp easy it's a matter of few hours to build, implement and debug a node. Awesome!LisaM wrote: ↑06 Aug 2017, 11:51I'm not surprised, i have looked long and hard to find anything simular to ESPEasy (8266 + wifi) and so far i haven't found it.It's like a HA Server for IOT devices and in that sense it's unique AND the first...grovkillen wrote: ↑06 Aug 2017, 11:24 I wish we could have status of how many user there's out there but one indication is the number of stars on github. We have reached 500+ now over the weekend and if I remember correctly we have risen from 400 stars in just about a month. Great!
But seriously I've been able to do so much with not much money because of ESP Easy, where I would have spend hundreds of dollars for commercial solutions.
Has anyone noticed that today it's been a full year after we published R120 stable.
Although this could ask for a small celebration, it also indicates that we have not been able to release the next stable within a reasonable time frame...
I'm not worried about R120, rather then a new release for V1 i would want to have a release of V2 (mega)...
I've dev11 running in 7 places in my home, some running on Sonoff (basic, pow) and some on home made ESP boards. I also am readying V2 for two ElectroDragons.
I propose to promote the mega branch to master and release the next dev as ESPEasy R200 stable.
With the ongoing development of ESP8266 MicroPython it's now in reach to rewrite ESPEasy in python. The ESP8266 hardware(with standard 8MB of flash memory on an ESP-01 module in Ali as latest record) is capable of supporting it although the minimum of 4MB should be required.
Performance test should be applied to verify if the performance is acceptable.
With using MicroPython, it would no longer be required to flash the ESP8266 other then to install MicroPython itself.ESPEasy python code should be in mainly two (fat) files: boot.py and main.py since micropython is using a fat filesystem after it becomes active. ESPEasy updates whould then mean to copy over some files and flash the firmware again. OTA, Serial and other update methods (with size limits) would no longer be required.
The rules section could become entirely python, giving a lot of additional options...
Uart, i2c, spi, DHT and NeoPixels are all standard present in micropython.
This will make ESPEasy a LOT easier, no need to run the loop() several times per second as we are currently doing...All pins except number 16 can be configured to trigger a hard interrupt if their input changes. You can set code (a callback function) to be executed on the trigger.
Be carefull with those ESP-01 with 8Mbyte shown at AliExpress.
It has shown that many of our chinese friends can't (or acidentally forgot to) differ between MBit and MByte
Every "8MByte" modul i tested showed up to be a 8MBit one....... in other words as a standard 1Mbyte type.
Give it a try.
Give it a try.
Thx for the warning.Shardan wrote: ↑11 Aug 2017, 13:24 Be carefull with those ESP-01 with 8Mbyte shown at AliExpress.
Give it a try.
I don't need one at this point, the esp's with 4MB are good enough for me. If i need a lot of memory then i'll buy a wemos with 16MB.
Other option is to buy a pyboard for $15, it has a shitload of io-ports (30!), sd card and other ports and a LOT of flash/ram memory...
With micropython, ESPEasy is no longer bound to the ESP8266.
This is already in use for ESP Easy as well. Just look at the pulse counter plugin where interrupts are hooked up to callback functions. The main loop handles everything that is not interrupt based. But it remains a single threaded process so using something like RTOS would be better for this kind of projects.LisaM wrote: ↑11 Aug 2017, 13:16This will make ESPEasy a LOT easier, no need to run the loop() several times per second as we are currently doing...All pins except number 16 can be configured to trigger a hard interrupt if their input changes. You can set code (a callback function) to be executed on the trigger.
But even when everything was irq based, beware that the ESP module can't access flash during irq handler and therefore all irq routines need to be stored in it's 32k instruction cache (IRAM). This is one of the major issues on the ESP8266 as well as it's limited 80k RAM that keeps us from building really powerful projects. Having 16MB flash is nice but this still doesn't mean that you can create huge projects for the ESP8266. Bottlenecks are RAM and IRAM and these can't be extended...
I think the LUA project has also struggled a lot with RAM issues... And so will likely any large interpreted environment suffer from the same RAM/IRAM limitations. Remember that the ESP8266 was actually never build with this in mind. Just a serial-wifi bridge...
