Water heating panel /Ds18b20 Temp
Hello guys
I ended my project to control the temperature of heating with underfloor heating through of water panels,
I will use 4 sensors DS18B20
- Sensor to see the temperature of the hot water that goes into home
- Sensor for the actual temperature of the water after leaving home
- Outdoor temperature
- Indoor temperature
After testing in bradboard , I decided move to the final version of my project, then started to build a board with the necessary components.
[attachment=0]IMG_20151115_200655.jpg[/attachment]
- Esp8266-01
- 2 x 4k7
- DC 5V to3.3V convert
- Micro USB
- 8 pin female
- ScrewTerminals
- Esp8266-01
- 2 x 4k7
- Micro USB
- 8 pin female
- ScrewTerminals
- IMG_20151115_200655.jpg (35.01 KiB) Viewed 15281 times
Re: Water heating panel /Ds18b20 Temp
[attachment=0]IMG_20151115_200633.jpg[/attachment]
- IMG_20151115_200633.jpg (35.49 KiB) Viewed 15280 times
the final version with enclouser
[attachment=0]IMG_20151115_192913.jpg[/attachment]
- IMG_20151115_192913.jpg (27.24 KiB) Viewed 15280 times
And This will work with domoticz, off course.
[attachment=0]IMG_20151115_193001.jpg[/attachment]
- IMG_20151115_193001.jpg (71.74 KiB) Viewed 15280 times
Really nice
I'm working on something similar for my underfloor heating (and am planning to use the output of the sensors to start/stop my circulation pumps).
I am planning to use a node MCU dev kit to avoid having to do my own PCB.
Where did you find the plastic casing ? It looks good and I cannot find suitable ones for the moment.
Thanks for sharing your project.
I has bougt this case here:
http://www.ebay.com/itm/321487958642?_t ... EBIDX%3AIT
but for nodemcu kit i think is a bit tie, so see the dimensions.
careful with output system, because it is unstable yet, the device sametimes reboot, i has tested with relay and happen.
Have a look here for a heating system in DMZ.
https://www.domoticz.com/forum/viewtopi ... it=heating
If the EASY ESP module looses connection the script will regain it settings and switch on or off the relay again depending on the needed situation of the thermostat setting.
If you are using NodeMCu and you have no solder skills then this breakout board might be handy
http://www.ebay.nl/itm/NodeMCU-Breakout ... Swo0JWPHKm
Paco
Paco
Thanks to both of you for the links.
hi guys
since the last project i was working to improve my floor heat control so i have done this:
i have change to a esp 12 because have more GPIO to play
, has add a jumpers to reset, Gpio0/gnd, and upgrade (have to put gnd and vcc by fti too only put RX/TX), add blue led when module are on, lcd to display the temperatures on local, and a switch to turn on/on the LCD (the switch is working by domoticz but i think better work like action control or logic level by esp easy but not implement, nobody tell me if we will get any day).
so this are the photos:
- rsz_img_20160104_234415.jpg (72.94 KiB) Viewed 14886 times
more
- rsz_2img_20160105_005618.jpg (55.51 KiB) Viewed 14886 times
more
- rsz_img_20160112_192827.jpg (74.69 KiB) Viewed 12928 times
more
- rsz_img_20160112_212240.jpg (65.93 KiB) Viewed 12928 times
so this was my renew project that i will offer to my daddy, lucky for him.
thanks esp easy for the support and the guys with the same doubt that was posted on forum and help me to understand minimal this stuff.
- rsz_img_20160112_212317.jpg (53.18 KiB) Viewed 12928 times
