Possible to set GPIO after successful sending?
zocker
#1 Post by zocker » 13 Sep 2017, 19:33
Hi to the forum,
i have a question on using the rules engine:
I'am reading a DHT22 sensor with my esp module using espeasy.
I configured espeasy to send the readings via HTTP to my server using the FHEM HTTP protocol.
This works fine ... no problem at all.
But i like to set a GPIO after successful sending the reading.
Is there a way to to this? Perhaps with a rule?
Exist a trigger event i can catch in the rule engine after the reading is sent?
Thx for your help.
Cheers Markus
Re: Possible to set GPIO after successful sending?
#2 Post by grovkillen » 13 Sep 2017, 19:58
I'm not sure I understand you correctly but if I do:
You will have to make the rule do all the publishing and then add a GPIO command after the publish. There's no trigger by default.
You can see this example here: https://www.letscontrolit.com/wiki/inde ... th_own_IDX
After the publish/sendtohttp you do a "gpio" set.
Users browsing this forum: Anthropic Claude Bot [bot] and 16 guests
