playzino
#1
Post
by playzino » 18 Sep 2017, 11:39
I have IRreciver connect to NodeMCU with ESPEASY 2.0, i try do triger some event usign MCE Remote (RC6). I Try this code:
On IR#IR=2148467803 do
pulse,4,1,100
But pulse is trigered by similare ir codes like 2148467804, 2148467805. IRceciver recive correct IR.
Any idea what's wrong?
playzino
#3
Post
by playzino » 18 Sep 2017, 14:14
This is 32bit, RC6 Code. In log and on serial monitor i see correct (different) code
IR#IR=2148467803
IR#IR=2148467804
IR#IR=2148467805
I try to use,
On IR#IR do
if IR#IR=2148467803 do
,but this dosn't work
Post
by grovkillen » 18 Sep 2017, 14:36
It's not the correct syntax. The "test" need to have the Device#Value in square brackets (see rules syntax
here).
On IR#IR do
if [IR#IR]=2148467803 do
playzino
#5
Post
by playzino » 18 Sep 2017, 14:39
ok thx, can I try some think like this?
On IR#IR do
if [IR#IR]-214846700=803 do
Post
by grovkillen » 18 Sep 2017, 14:43
You might, I haven't tested that one exactly (with the arithmetic on the left side). But it could work. Please report back
playzino
#7
Post
by playzino » 18 Sep 2017, 19:07
Arithmetic on the left side don't work.
LOG:
66189409 : IR : Code 800f045c - Type: 2 - Bits: 36
66189423 : EVENT: IR#IR=2148467804
66189470 : ACT : pulse,5,1,100
66189571 : SW : GPIO 5 Pulsed for 100 mS
Rules
On IR#IR do
pulse,5,1,100
Any idea???
toffel969
#8
Post
by toffel969 » 18 Sep 2017, 21:27
playzino wrote: ↑18 Sep 2017, 19:07
LOG:
Rules
On IR#IR do
pulse,5,1,100
Any idea???
On IR#IR do
pulse,5,1,100
should be
On IR#IR do
pulse,5,1,100
there is not supposed to be a "do" in the if statement
not sure if this solves your problem though
playzino
#9
Post
by playzino » 18 Sep 2017, 21:36
Oh yeah, now is missing do, but the problem is that this rules works TO GOOD. Rules is executed by similar codes not only THIS code.
BTW. It is possible to use var in Rules?
toffel969
#10
Post
by toffel969 » 19 Sep 2017, 08:29
playzino wrote: ↑18 Sep 2017, 21:36
Ya but when dealing with unexpected behaviour, it is best t respect the syntax. "Do" for events, "[]" for the value compared in if.
Variables should be possible as dummy devices. You can save 4 var per device
Domosapiens
#11
Post
by Domosapiens » 19 Sep 2017, 18:12
On IR#IR do
I'm not sure that using the same name for "Task Name" and "Value Name" is allowed.
I vaguely remember that I had problems with that.
Hope this helps
Domosapiens
playzino
#12
Post
by playzino » 29 Sep 2017, 13:35
Tested on 26bit codes from other remote and works fine. Definitely have problem with 36bits codes.
Drum
#13
Post
by Drum » 08 Oct 2017, 09:16
Might this explain it???
From the Wiki:
"Remember that you can only store floating point numbers as output from your device. Also note that the floating point precision is limited. For most application this will not lead to issues but storing a large 32 bit number like RFID tags will get rounded. As a workaround, you can store this into two floating point variables as 16 bit parts. Selecting SENSOR_TYPE_LONG will handle this within the framework. But it supports only one long value!"
papperone
#14
Post
by papperone » 08 Oct 2017, 10:13
Drum wrote: ↑08 Oct 2017, 09:16
From the Wiki:
I can confirm this as I faced similar problem when developping my HLW8012 plugin; calibration value were needed to be DOUBLE and not to be rounded so I ended up with saving them as "Custom Settings".
This is definitely doable and it works a charm so if needed as well for RFID readings of large tags then someone needs to implement it in the relevant pluing code.
Users browsing this forum: Google [Bot] and 20 guests
