Rotary Switch doesn‘t count
olem_de
#1 Post by olem_de » 03 Nov 2017, 21:46
I have a problem with the rotary switch:it does not count !
I have connected the two outer pins of the switch (Not a shield with pwr and gnd) to the gpio‘s,configured them ...but no counting at all. Do i have to connect the pins via a resistier to Vcc?
Thx if someone has a hint or workaround .
Ole
Re: Rotary Switch doesn‘t count
#2 Post by grovkillen » 03 Nov 2017, 21:56
A picture or two of your setup would help. Have you rebooted the ESP after the configuration is done (just to be sure)?
olem_de
#3 Post by olem_de » 03 Nov 2017, 22:20
ok . yes i did a reboot
#4 Post by grovkillen » 03 Nov 2017, 22:27
What about the rotary encoder? Possible to have a picture/name of it?
And:
Do not use GPIO 16 for this plugin, it will not work properly.
https://www.letscontrolit.com/wiki/inde ... ry_Encoder
Do you need it to be reset by the use of "I"? You can at least try without it.
olem_de
#5 Post by olem_de » 03 Nov 2017, 22:33
such a type
#6 Post by grovkillen » 03 Nov 2017, 22:34
Great, let's try without the gpio 16 first.
olem_de
#7 Post by olem_de » 03 Nov 2017, 22:41
i tried this first - no success
Users browsing this forum: Ahrefs [Bot] and 20 guests
