VEML 6070 UV Light Sensor
sash.sc
#1 Post by sash.sc » 17 May 2017, 15:42
Hello everybody
I am building a sensor that detects moisture, temp and air pressure (BME280). The light is detected with another sensor via I²C.
I have now ordered a VEML 6070 UV light sensor. But had to find that this is not supported.
Is it possible to integrate it into ESPEasy?
Here is a sample page with Arduino code.
https://github.com/watterott/VEML6070-Breakout
I do not have the same sensor, but should help, right?
Greetings and thanx for your help.
Sascha
krikk
Re: VEML 6070 UV Light Sensor
#2 Post by krikk » 17 May 2017, 19:22
should be no problem to integate, because its "just" another i2c sensor... but someone has to code it :)
....is you don't want to code, take one of the supported light sensors: https://www.letscontrolit.com/wiki/inde ... FActuators
sash.sc
#3 Post by sash.sc » 18 May 2017, 14:16
The supported sensors are ok, but there is noch UVlight Sensor.
If i can, i would code it, but i can't. I've no knowledge to do this.
Greetings
Sascha
sash.sc
#4 Post by sash.sc » 28 Jan 2018, 14:17
Hi @all.
At the FHEM Forum, Joerg Wiemann, has compiled ESPEasy with the VEML Sensor.
Both Files are attached at the zip.
https://forum.fhem.de/index.php/topic,63931.0.html
Can you merge it to espeasy mega?
Greetings
Sash
#5 Post by Shardan » 28 Jan 2018, 14:45
+1
#6 Post by TD-er » 28 Jan 2018, 20:52
Can you please add an issue for it? https://github.com/letscontrolit/ESPEasy/issues
Users browsing this forum: Anthropic Claude Bot [bot] and 20 guests
