Hello everybody
I am building a sensor that detects moisture, temp and air pressure (BME280). The light is detected with another sensor via I²C.
I have now ordered a VEML 6070 UV light sensor. But had to find that this is not supported.
Is it possible to integrate it into ESPEasy?
Here is a sample page with Arduino code.
https://github.com/watterott/VEML6070-Breakout
I do not have the same sensor, but should help, right?
Greetings and thanx for your help.
Sascha
VEML 6070 UV Light Sensor
Re: VEML 6070 UV Light Sensor
should be no problem to integate, because its "just" another i2c sensor... but someone has to code it
....is you don't want to code, take one of the supported light sensors: https://www.letscontrolit.com/wiki/inde ... FActuators
The supported sensors are ok, but there is noch UVlight Sensor.
If i can, i would code it, but i can't. I've no knowledge to do this.
Greetings
Sascha
Greetings
Sascha
Hi @all.
At the FHEM Forum, Joerg Wiemann, has compiled ESPEasy with the VEML Sensor.
Both Files are attached at the zip.
https://forum.fhem.de/index.php/topic,63931.0.html
Can you merge it to espeasy mega?
Greetings
Sash
Greetings
Sash
Can you please add an issue for it? https://github.com/letscontrolit/ESPEasy/issues
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 16 guests
