EVENT call from MQTT
leel1967l
#1 Post by leel1967l » 01 Feb 2018, 09:39
I am building my first project integrating ESPEASY and OPENHAB2.
I would like to understand how I can send and event call from MQTT.
In other words, I would like to trigger a rule from MQTT.
I know how it can be done using http: http://<espeasyip>/control?cmd=event,remoteTimerControl=5
But I need to do in MQTT.
How can this be achieved?
thanks
Re: EVENT call from MQTT
#2 Post by grovkillen » 01 Feb 2018, 10:11
leel1967l
#3 Post by leel1967l » 01 Feb 2018, 11:31
grovkillen wrote: 01 Feb 2018, 10:11 Wiki is your friend: https://www.letscontrolit.com/wiki/inde ... _Reference
Hi @grovkillen,
I appreciate your help, but I had already checked that page and the tutorial page.
I couldn't find an example of how to format the syntax of a MQTT request to call an EVENT.
For a GPIO the syntax that I use is:
Switch Sonoff1 {mqtt=">[mymosquitto:/Sonoff_1/gpio/12:command:ON:1],>[mymosquitto:/Sonoff_1/gpio/12:command:OFF:0]"}
What should be the syntax for an EVENT?
thanks
#4 Post by grovkillen » 01 Feb 2018, 14:14
Topic:
<unitname>/cmd
Payload:
leel1967l
#5 Post by leel1967l » 01 Feb 2018, 15:01
grovkillen wrote: 01 Feb 2018, 14:14 Topic:
<unitname>/cmd
Payload:
will try tonight thanks
leel1967l
#6 Post by leel1967l » 01 Feb 2018, 23:11
<unitname>/cmd
Payload:
I can't understand the syntax.
Tried this in Openhab, but it did not trigger any rule in ESPeasy:
{mqtt=">[mymosquitto:/Sonoff_1/cmd/event:command:remoteTimerControl=5:0]"}
Rule is (works with http call):
on remoteTimerControl do
  TaskValueSet 5,1,%eventvalue%
#7 Post by grovkillen » 02 Feb 2018, 06:06
leel1967l wrote: 01 Feb 2018, 23:11
<unitname>/cmd
Payload:
This is a openhab issue. I don't use that controller myself. But to start I would use a mqtt viewer (I use MQTT snooper). That way you can see what the actual message from openhab looks like.
The being said, my guess is that you want the config file to read something like this:
{mqtt=">[mymosquitto:/Sonoff_1/cmd:command:event,remoteTimerControl=5:0]"}
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot], YandexBot [bot] and 16 guests
