EVENT call from MQTT
I am building my first project integrating ESPEASY and OPENHAB2.
I would like to understand how I can send and event call from MQTT.
In other words, I would like to trigger a rule from MQTT.
I know how it can be done using http: http://<espeasyip>/control?cmd=event,remoteTimerControl=5
But I need to do in MQTT.
How can this be achieved?
thanks
thanks
Re: EVENT call from MQTT
Wiki is your friend: https://www.letscontrolit.com/wiki/inde ... _Reference
Hi @grovkillen,grovkillen wrote: ↑01 Feb 2018, 10:11 Wiki is your friend: https://www.letscontrolit.com/wiki/inde ... _Reference
I appreciate your help, but I had already checked that page and the tutorial page.
I couldn't find an example of how to format the syntax of a MQTT request to call an EVENT.
For a GPIO the syntax that I use is:
Switch Sonoff1 {mqtt=">[mymosquitto:/Sonoff_1/gpio/12:command:ON:1],>[mymosquitto:/Sonoff_1/gpio/12:command:OFF:0]"}
What should be the syntax for an EVENT?
thanks
Topic:
Payload:
<unitname>/cmd
will try tonight thanksgrovkillen wrote: ↑01 Feb 2018, 14:14 Topic:Payload:Code: Select all
<unitname>/cmd
Hi,grovkillen wrote: ↑01 Feb 2018, 14:14 Topic:Payload:Code: Select all
<unitname>/cmd
I can't understand the syntax.
Tried this in Openhab, but it did not trigger any rule in ESPeasy:
{mqtt=">[mymosquitto:/Sonoff_1/cmd/event:command:remoteTimerControl=5:0]"}
on remoteTimerControl do
TaskValueSet 5,1,%eventvalue%
This is a openhab issue. I don't use that controller myself. But to start I would use a mqtt viewer (I use MQTT snooper). That way you can see what the actual message from openhab looks like.leel1967l wrote: ↑01 Feb 2018, 23:11Hi,grovkillen wrote: ↑01 Feb 2018, 14:14 Topic:Payload:Code: Select all
<unitname>/cmd
Tried this in Openhab, but it did not trigger any rule in ESPeasy:Rule is (works with http call):Code: Select all
on remoteTimerControl do TaskValueSet 5,1,%eventvalue% endon
The being said, my guess is that you want the config file to read something like this:
{mqtt=">[mymosquitto:/Sonoff_1/cmd:command:event,remoteTimerControl=5:0]"}
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 20 guests
