How can adjust frequency of publishing messages via mqtt (ESPeasy R120) ?
I thought that "Sensor Delay" (default: 60) in Config section is appropriate settings but.. it is not.
I'm changing for 300 (5 min?).. and nothing.. messages are still published every 60 seconds.
If there is another settings which controls this interval?
Regards,
M
MQTT publishing frequency
Re: MQTT publishing frequency
Please post your settings. Use my webdumper if you're on Windows.
Please find attached my config.
grovkillen wrote: ↑04 Feb 2018, 20:24 Please post your settings. Use my webdumper if you're on Windows.
And for your devices as well.
The delay there is the setting you use for the interval.
OK... My device.
So.. "Delay" for device?
grovkillen wrote: ↑04 Feb 2018, 22:47 And for your devices as well.
And there you have your publish interval for that particular device. 60 seconds.
It works. Thank you for support.
Greetings,
M
Greetings,
M
grovkillen wrote: ↑05 Feb 2018, 05:53 And there you have your publish interval for that particular device. 60 seconds.
Users browsing this forum: Anthropic Claude Bot [bot], OpenAI Searchbot [bot] and 13 guests
