MQTT publishing frequency
macle
#1 Post by macle » 04 Feb 2018, 00:00
How can adjust frequency of publishing messages via mqtt (ESPeasy R120) ?
I thought that "Sensor Delay" (default: 60) in Config section is appropriate settings but.. it is not.
I'm changing for 300 (5 min?).. and nothing.. messages are still published every 60 seconds.
If there is another settings which controls this interval?
Regards,
M
macle
Re: MQTT publishing frequency
#2 Post by macle » 04 Feb 2018, 20:15
Anyone?? ;-)
#3 Post by grovkillen » 04 Feb 2018, 20:24
Please post your settings. Use my webdumper if you're on Windows.
macle
#4 Post by macle » 04 Feb 2018, 22:37
Please find attached my config.
grovkillen wrote: 04 Feb 2018, 20:24 Please post your settings. Use my webdumper if you're on Windows.
#5 Post by grovkillen » 04 Feb 2018, 22:47
And for your devices as well.
The delay there is the setting you use for the interval.
macle
#6 Post by macle » 04 Feb 2018, 23:25
OK... My device.
So.. "Delay" for device?
grovkillen wrote: 04 Feb 2018, 22:47 And for your devices as well.
#7 Post by grovkillen » 05 Feb 2018, 05:53
And there you have your publish interval for that particular device. 60 seconds.
macle
#8 Post by macle » 05 Feb 2018, 13:18
It works. Thank you for support.
Greetings,
M
grovkillen wrote: 05 Feb 2018, 05:53 And there you have your publish interval for that particular device. 60 seconds.
Users browsing this forum: Anthropic Claude Bot [bot] and 26 guests
