no connection to ssid
Homer-S
#1 Post by Homer-S » 04 Feb 2018, 22:20
I am using v2.0 to access my homenet
I followed exactly the tutorial.
All is running like expected but when I entered ssid and my pass it is going into an endless loop to enter the ssid stuff.
I found a fitting threat but without an end/solution.
Do you have an idea where to look for a solution?
Might be my pass a problem? it contains special characters, could it be a unicode issue?
Re: no connection to ssid
#2 Post by TD-er » 05 Feb 2018, 09:49
Can you see what label is written on the flash chip? (e.g. "PUYA") And the ESP chip? (ESP8266/8285)
Or is the ESP + flash chip covered with a metal shield?
And what version (filename) of the firmware did you use?
Homer-S
#3 Post by Homer-S » 05 Feb 2018, 18:24
I added two pictures to answer your questions.
I flashed this one:
ESP_Easy_v2.0-20180203_normal_ESP8266_4096
#4 Post by TD-er » 05 Feb 2018, 22:45
OK, Wemos D1 mini should work without issues.
What kind of special characters do you have in the SSID or password?
Homer-S
#5 Post by Homer-S » 06 Feb 2018, 07:10
There is a %! inside
Funny story:
As desperate I was i used this one:
viewtopic.php?f=4&t=3934
after flashing it showed same behavior.
Today when i tried it again (plugged USB in the Laptop) it connected and it is working ...
with all attempted before even with un-/plug cable it did not work ...
Thanks anyway for your support.
#6 Post by grovkillen » 06 Feb 2018, 09:15
Homer-S wrote: 06 Feb 2018, 07:10 There is a %! inside
Funny story:
Aha, the percent character is not recommended for sure. We need to add information on the wiki. Thanks!
#7 Post by TD-er » 06 Feb 2018, 12:19
Was it one of the newer builds that eventually worked?
Or did you set the Wifi password via another route?
#8 Post by grovkillen » 06 Feb 2018, 12:36
It could be my flash wrapper that didn't like the percent character...
Users browsing this forum: Ahrefs [Bot] and 10 guests
