Hello all,
I have a few Wemos D1 mini and I want to put a new software on it.
So I tried to re-flash the devices by the Flashtool, but all devices don't start.
The flashtool reported success before.
I do not see them in my WiFi net or as an access point.
I tried V2.0.0 dev 12, 20180118 and the newest 20180209
What do I wrong?
BR
How to re-flash an ESP?
Re: How to re-flash an ESP?
You may have settings left on the unit? Reset command will erase the configuration file.
Now it works.
I tried the old R120 Version, then I had this ESP_0 AP.
I don't know why just the old version works for re-flashing!
Because you previously had Rxx version on it with that versions config file.
Look at this post(s): http://letscontrolit.com/forum/viewtopi ... 367#p24367
Maybe it's the same problem like many others. The flash-chip only works in DOUT-mode.
Test the image from TD-er and flash it from commandline with this batch:
@echo off
set /p comport= Comport (example 3, 4, ..) :
esptool.exe -vv -cd nodemcu -cb 115200 -cp COM%comport% -ca 0x00000 -bm dout -cf ESPeasy_v2.0.0-2018-02-08_DOUT.bin
pause
Yes you're right. That's probably the answer.
Hmm if it's more common, we should perhaps change all the 1M builds to DOUT mode?
Yeah we might need to do that.
Users browsing this forum: Anthropic Claude Bot [bot], OpenAI Searchbot [bot] and 16 guests
