How to re-flash an ESP?
Tobi993
#1 Post by Tobi993 » 10 Feb 2018, 08:08
Hello all,
I have a few Wemos D1 mini and I want to put a new software on it.
So I tried to re-flash the devices by the Flashtool, but all devices don't start.
The flashtool reported success before.
I do not see them in my WiFi net or as an access point.
I tried V2.0.0 dev 12, 20180118 and the newest 20180209
What do I wrong?
BR
Re: How to re-flash an ESP?
#2 Post by grovkillen » 10 Feb 2018, 09:17
You may have settings left on the unit? Reset command will erase the configuration file.
Tobi993
#3 Post by Tobi993 » 10 Feb 2018, 10:18
Now it works.
I tried the old R120 Version, then I had this ESP_0 AP.
I don't know why just the old version works for re-flashing!
#4 Post by grovkillen » 10 Feb 2018, 10:25
Because you previously had Rxx version on it with that versions config file.
Micha_he
#5 Post by Micha_he » 10 Feb 2018, 10:31
Look at this post(s): http://letscontrolit.com/forum/viewtopi ... 367#p24367
Maybe it's the same problem like many others. The flash-chip only works in DOUT-mode.
Test the image from TD-er and flash it from commandline with this batch:
@echo off
set /p comport= Comport (example 3, 4, ..)           :
esptool.exe -vv -cd nodemcu -cb 115200 -cp COM%comport% -ca 0x00000 -bm dout -cf ESPeasy_v2.0.0-2018-02-08_DOUT.bin
pause
#6 Post by grovkillen » 10 Feb 2018, 13:27
Yes you're right. That's probably the answer. :roll:
#7 Post by TD-er » 10 Feb 2018, 15:23
Hmm if it's more common, we should perhaps change all the 1M builds to DOUT mode?
#8 Post by grovkillen » 10 Feb 2018, 16:17
Yeah we might need to do that.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 12 guests
