How flexible are if statements w/ %eventvalue%v?
Methuselah
#1 Post by Methuselah » 20 Feb 2018, 16:15
Given the following code:
on SetOutsideTemp do
if %eventvalue% <> [T1#A]
TaskValueSet 9,1,%eventvalue%
Test1 Failed
if [T1#A] <> %eventvalue%
Test2 failed
T1#A=[T1#A]
Given [T1#A] equals 55.5, executing the following:
http://my.ip/control?cmd=event,SetOutsideTemp=55.3
yields the following in my output log:
EVENT: SetOutsideTemp=55.3
ACT: Test1 failed
ACT: TestValueSet 9,1,55.3
ACT: [T1#A]=55.3
EVENT: Processing time 1712 milliseconds
From this output, should I conclude %eventvalue% is only evaluated on the right of the conditional expression?
N00b to the world of ESPEasy, but I've been programming since the days of punch cards and paper tape :)
Methuselah
Re: How flexible are if statements w/ %eventvalue%v?
#2 Post by Methuselah » 20 Feb 2018, 16:30
Also.... The test condition does not seem to like a device value initialized to zero, e.g.
on System#Boot do
 TaskValueSet 9,1,0.0
Test1 Failed
Test2 failed
T1#A=[T1#A]
Yields:
ACT: Test1 failed
ACT: Test2 failed
ACT: [T1#A]=0.0
EVENT: Processing time 1676 milliseconds
I can only get the test condition to evaluate correctly if [T1#A] is initialized to a value greater than 0 in System#Boot. Negative values also do not seem to evaluate properly (e.g. a TaskSetValue of -100 in System#Boot will likewise cause the test conditions to evaluate false when when they should be true)
(using the mega 2018-20-19 build)
vader
#3 Post by vader » 20 Feb 2018, 21:22
Only one operator is allowed. <> is not allowed. See source code...
switch (compare)
case '>':
if (Value1 > Value2)
match = true;
case '<':
if (Value1 < Value2)
match = true;
case '=':
if (Value1 == Value2)
match = true;
Methuselah
#4 Post by Methuselah » 20 Feb 2018, 23:59
Thanks. Interesting. I didn't realize there was no inequality operator.
what would be the proper way to check for inequality then?
if something
do commands
or
if something
delay 0
do commands
budman1758
#5 Post by budman1758 » 21 Feb 2018, 03:01
Perhaps a study of this link will help?
https://www.letscontrolit.com/wiki/inde ... rial_Rules
vader
#6 Post by vader » 21 Feb 2018, 13:45
You can try this:
on %eventvalue% < [T1#A] do //Check 1st if lower
if %eventvalue% > [T1#A] //Check 2nd if higher, so we also have a <> comparison ;)
bla, bla....
more bla, bla.... :mrgreen:
Methuselah
#7 Post by Methuselah » 21 Feb 2018, 18:14
vader wrote: 21 Feb 2018, 13:45 You can try this:
Thanks for your input Vader. I guess I need to make it a point of looking through the code base more than I have in the past.
duytruong
#8 Post by duytruong » 24 Feb 2018, 04:24
Methuselah wrote: 20 Feb 2018, 16:15 Given the following code:
You'd better assign %eventvalue% to a Dummy device than using it directly.
#9 Post by TD-er » 24 Feb 2018, 17:31
vader wrote: 20 Feb 2018, 21:22 Only one operator is allowed. <> is not allowed. See source code...
I added this as suggestion to this PR/issue: https://github.com/letscontrolit/ESPEas ... -368237502
Methuselah
#10 Post by Methuselah » 26 Feb 2018, 00:16
TD-er wrote: 24 Feb 2018, 17:31
Read the thread. Sweet. Image
