Publish switch states to ThingSpeak
dermeb
#1 Post by dermeb » 22 Dec 2015, 13:04
Hello everyone!
Awesome project! I really like it and try to set up some nodes.
It works quite well. I upload my sensor data to thingspeak for further processing.
Temperature and humidity data from DHT sensors are working neatly.
But when I try to publish the data of a switch input it doesn't seem to work.
If I export the data from thingspeak, i just get empty entries like:
created_at,entry_id,field1,field2,field3
2015-12-22 11:43:15 UTC,1,,,
2015-12-22 11:43:31 UTC,2,,,
2015-12-22 11:44:01 UTC,3,,,
2015-12-22 11:45:32 UTC,4,,,
2015-12-22 11:45:46 UTC,5,,,
Has anyone managed to get switch-inputs to thingspeak?
Thank you!
Michael
dermeb
Re: Publish switch states to ThingSpeak
#2 Post by dermeb » 22 Dec 2015, 13:49
After some code diving, I found the solution myself.
It wasn't implemented yet for the SENSOR_TYPE_SWITCH!
So i copied the code from SENSOR_TYPE_SINGLE, and it works like a charm :)
in _C004:
 switch (event->sensorType)
          case SENSOR_TYPE_SINGLE:                      // single value sensor, used for Dallas, BH1750, etc
            postDataStr += F("&field");
            postDataStr += event->idx;
            postDataStr += "=";
            postDataStr += String(UserVar[event->BaseVarIndex]);
          case SENSOR_TYPE_TEMP_HUM:                      // dual value
          case SENSOR_TYPE_TEMP_BARO:
            postDataStr += "=";
            postDataStr += event->idx + 1;
            postDataStr += "=";
            postDataStr += String(UserVar[event->BaseVarIndex + 1]);
          case SENSOR_TYPE_SWITCH:
            postDataStr += "=";
Greetings
Michael
Martinus
#3 Post by Martinus » 22 Dec 2015, 14:00
Instead of copying the code it's easier to add the case statement below the first one like this:
            postDataStr += "=";
I'll add it in R56.
dermeb
#4 Post by dermeb » 22 Dec 2015, 14:06
That's a nice trick, thanks!
I'll add it in R56.
Great! :)
