Hello everyone!
Awesome project! I really like it and try to set up some nodes.
It works quite well. I upload my sensor data to thingspeak for further processing.
Temperature and humidity data from DHT sensors are working neatly.
But when I try to publish the data of a switch input it doesn't seem to work.
If I export the data from thingspeak, i just get empty entries like:
created_at,entry_id,field1,field2,field3
2015-12-22 11:43:15 UTC,1,,,
2015-12-22 11:43:31 UTC,2,,,
2015-12-22 11:44:01 UTC,3,,,
2015-12-22 11:45:32 UTC,4,,,
2015-12-22 11:45:46 UTC,5,,,
Has anyone managed to get switch-inputs to thingspeak?
Thank you!
Michael
Publish switch states to ThingSpeak
Re: Publish switch states to ThingSpeak
After some code diving, I found the solution myself.
It wasn't implemented yet for the SENSOR_TYPE_SWITCH!
So i copied the code from SENSOR_TYPE_SINGLE, and it works like a charm
in _C004:
Greetings
Michael
in _C004:
switch (event->sensorType)
case SENSOR_TYPE_SINGLE: // single value sensor, used for Dallas, BH1750, etc
postDataStr += F("&field");
postDataStr += event->idx;
postDataStr += "=";
postDataStr += String(UserVar[event->BaseVarIndex]);
case SENSOR_TYPE_TEMP_HUM: // dual value
case SENSOR_TYPE_TEMP_BARO:
postDataStr += "=";
postDataStr += event->idx + 1;
postDataStr += "=";
postDataStr += String(UserVar[event->BaseVarIndex + 1]);
case SENSOR_TYPE_SWITCH:
postDataStr += "=";
Greetings
Michael
Instead of copying the code it's easier to add the case statement below the first one like this:
I'll add it in R56.
postDataStr += "=";
That's a nice trick, thanks!
Great!I'll add it in R56.
