Debugging crashes
riker1
Debugging crashes
#1 Post by riker1 » 02 Mar 2018, 13:12
just want to understand debugging options ....
while having a temp sensor attachted to the ESP01s it worked fine.
Now I placed it into a box and mounted it, - no easy access - it crashes and I have to unplug the power to reboot.
Syslog is not showing a problem
last entry: Unit: 174 : WD : Uptime 35 ConnectFailures 0 FreeMem 24848
Load is not high:
Load: 22% (LC=25738)
any hints for this approach?
Thanks T
Re: Debugging crashes
#2 Post by TD-er » 02 Mar 2018, 23:04
Power supply? Placed in some box where WiFi reception is poor?
The pins used by the temp sensor have no pull-up resistors active and acts as some kind of antenna?
riker1
#3 Post by riker1 » 03 Mar 2018, 07:50
Hi TD-er,
thanks for the hints,
checked them.
power is providing 400 mA, should be sufficient.
I can not get a value out from system info : Input VCC...
after reboot it reconnects to wifi perfect
it is close to the router.
signal is always around:
Wifi RSSI: -66 dB
Resistor is used for temp sensor ds18b20
Domosapiens
#4 Post by Domosapiens » 03 Mar 2018, 11:06
I doubt. During WiFi activity the ESP is power hungry.
The Wiki:
USB power supply
If you want to use a USB charger as a power supply, make sure it has a CE marking and delivers enough current. 1 Ampere is the least.
https://www.letscontrolit.com/wiki/inde ... wer_supply
#5 Post by TD-er » 03 Mar 2018, 19:15
You could add some elco over the 3V3 line to shave off the peak current.
riker1
#6 Post by riker1 » 19 Mar 2018, 09:47
Thanks TD,
looks it is a heat problem of the buck converter.
getting to warm in the box
Users browsing this forum: opensiteexplorer.org/dotbot [bot] and 26 guests
