Wemos D1 mini configured on ESPEasy with 3600s in deep sleep delay using a I2C SHT30 Wemos shield to send temperature to an MQTT server awake from deep sleep around each 5 mn.
The same board with a DHT22 Wemos works well.
Any idea ?
SHT30 deep sleep > 5 mn
Re: SHT30 deep sleep > 5 mn
How did you wire the "wake" pin?
thanks for your help.
I use the same board for the DTH22 or the SHT30 .
The only difference is on ESPeasy device configuration DHT22 or SHT30.
It's a Wemos D1 mini V3.0.0 with a jumper SJ1 on the back of the board to solder to enable wake up on deep sleep
That means RST pin connected to GPIO16 pin.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 13 guests
