I tried to copy it as is and it does not work.%c_cm2imp%([TaskName#ValueName])
Also, I tried this, but it does not work either:
How should I use this formula? Can someone help me?%c_cm2imp%(%value%)
Thank you.
Sorry, I might need to move that to another section.You can convert integers and floats into human readable information using these commands. These are not working in formulas since the output is a string and not a true float value. The intended use is in rules (Publish command as an example) and displays etc.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 14 guests
