Devices -> Value -> Formula
onlize
#1 Post by onlize » 18 Mar 2018, 18:47
I am trying to understand how to convert output that I have in centimeter to imperial (feet) + inches. The example that I see is:
%c_cm2imp%([TaskName#ValueName])
I tried to copy it as is and it does not work.
Also, I tried this, but it does not work either:
%c_cm2imp%(%value%)
How should I use this formula? Can someone help me?
Thank you.
Re: Devices -> Value -> Formula
#2 Post by grovkillen » 18 Mar 2018, 20:41
You can convert integers and floats into human readable information using these commands. These are not working in formulas since the output is a string and not a true float value. The intended use is in rules (Publish command as an example) and displays etc.
Sorry, I might need to move that to another section.
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 21 guests
