Get the timer value
Gilles
Get the timer value
#1 Post by Gilles » 04 Mar 2019, 15:05
I am using a sonoff/espeasy to power on a a lamp during 2 hours via a rule and a timer :
On Relai#Relai do
 if [Relai#Relai]=1
    timerSet,1,7200 //timer 1 set for 2 heures
    timerSet,1,0
Is there a way to get the value of the timer to know how much time is left in the same way as I can get the status of a gpio using : http://x.x.x.x/control?cmd=status,gpio,12
I have read something about the dummy devices where I could store a second timer, but I have not really understood how does it work and how to get its value.
What should I do ?
version : Build: 20000 - Mega
GIT version: (custom)
Re: Get the timer value
#2 Post by grovkillen » 04 Mar 2019, 18:15
On Relai#Relai do
 if [Relai#Relai]=1
    TimerSet,8,1
    Let,1,7200
    timerSet,1,0
    TimerSet,8,0
 On Rules#Timer=1 Do
  //Do your thing
  Let,1,0
  EndOn
  On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
   //You can push the value of variable 1 to either an event, a dummy value or whatever
   TimerSet,8,1
  EndOn
Gilles
#3 Post by Gilles » 05 Mar 2019, 09:14
Thanks,
I will give it a try.
Is the "Let" command explained somewhere? I went through the wiki and have not found it.
Gilles
#4 Post by grovkillen » 05 Mar 2019, 12:08
No I haven't had the time to document that yet.
Patou
#5 Post by Patou » 06 Mar 2019, 22:29
Pleas find enclosed a document explaining the let fucntion
Found on several forum discussions
Good reading
Patou
Esp Easy internal variables
There are 16 definable internal variables :
Let,<value number 1...16>,<float>
Example
Let,1,10
Let,2,20
Publish,Answer/%v1%+%v2%,(%v1%+%v2%)
or
Publish,Answer/[var#1]%+[var#2],([var#1]%+[var#2])
This would render in this being published
Topic
Answer/10+20
Message 30
New way :
On System#Boot Do
Let,1,123456789
EndOn
On esp004#tag Do
Let,2,[esp004#tag] //Setting dummy value 1 to the tag code
TimerSet,1,3
EndOn
On Rules#Timer=1 Do
If [esp004#tag] = %v2%
taskValueSet,1,1,%v1%
EndIf
Old way :
On System#Boot Do
taskValueSet,12,2,123456789
EndOn
On esp004#tag Do
taskValueSet,12,1,[esp004#tag] //Setting dummy value 1 to the tag code
TimerSet,1,3
EndOn
On Rules#Timer=1 Do
If [esp004#tag] = [Dummy#CurrentTag] //If the tag code is still the same after 3 seconds clear it
taskValueSet,1,1,[Dummy#ZeroTag]
EndIf
EndOn
Is it possible to create a feature so you can do some elementary basic signal processing on
• the sensor signals? searched the issue tracker or the forum for a similar issue. (include links when applicable) But i did not find any info on this
• There is a rather elaborate filter option which you can already use now.
You can store values in a variable when using rules. Something similar can also be done using the dummy plugin.
These values can then be used in a computation (in the rules).
For example new value = (3* last_value + new sample) / 4
And then store that new value in the variable to be used in the next run as "last_value".
• But I agree that some statistics module would be very useful.
On the other hand, if the values jump 4 degree between samples, then you can ask yourself how useful these are.
So maybe better to look into why these values are so unstable.
Ah, what you describe is what i meant, but didn't realize it was there. maybe close the request than.
But i'm very new to this, so not sure how to do that precisely. I found the rule tab now.
I copied the new value = (3* last_value + new sample) / 4 there but do not know how to put the And then store that new value in the variable to be used in the next run as "last_value". to work.....
Could you give an example, or a headsup where to look? (as i mentioned, really new here)
I will summon the rules guru by mentioning him ;)
@Grovkillen may be able to help here.
Or if it will end up in a discussion on how to do stuff instead of things that are buggy or need to change, then it may be best to move it to the forum.
This is what I would try first. I store the last 9 values and add the newest value to that making it 10 values all in all. The average of those ten is then added to a dummy variable (task 12 in this example) which is then later used as the publishing task.
On Temp#Value Do
Let,10,[VAR#9]
Let,9,[VAR#8]
Let,8,[VAR#7]
Let,7,[VAR#6]
Let,6,[VAR#5]
Let,5,[VAR#4]
Let,4,[VAR#3]
Let,3,[VAR#2]
Let,2,[VAR#1]
Let,1,[Temp#Value]
TaskValueSet,12,1,([VAR#1]+[VAR#2]+[VAR#3]+[VAR#4]+[VAR#5]+[VAR#6]+[VAR#7]+[VAR#8]+[VAR#9]+[VAR#10])/10
EndOn
Right at boot all the internal variables will be 0 making this rule not working great for the first ten loops.
PS. TaskValueSet could be accompanied by TaskRun in order to have the value being published in the same intervals as the actual sensor is set to (in this example named Temp#Value). I close this one now.
Why use 10 samples? If you only use the a weighted average of the last reported value (not measured) combined with the last measured value, you will achieve similar filtering but a lot easier to implement in rules.
Only drawback is that you will still have some residue left of old values when the measured values suddenly change a lot. Taking the average of a fixed amount of samples will have no "memory" after N samples.
So it depends on the use case which is better.
For example on a scale you want a fast response (using average filtering), but when keeping track of air pressure you don't want to see someone slamming the door.
On Temp#Value Do
Let,2,[VAR#1]*3
Let,1,[Temp#Value]
TaskValueSet,12,1,([VAR#1]+[VAR#2])/4
EndOn
Gilles
#6 Post by Gilles » 07 Mar 2019, 07:27
Thanks Patou,
I have also find a command reference which talks about the "let" statement : https://espeasy.readthedocs.io/en/lates ... mmand.html
I have spent some time yesterday based on grovkillen's solution to try to make it work, but not yet succeeded.
I don't understand how I can get the value of the time left to get it with a http command.
I am confused with the "dummy device" and the "dummy variable".I have found some complex posts, but nothing simple and clear to me.
I think that I need to create a rule "abcd", to run it ( http://xxx.xxx.x.x/control?cmd=event,abcd), It should trigger the calculation of the time left in the [VAR#1] variable. In // I create a dummy device with a variable to which I will assign the [VAR#1], something like that.
I don't understand the statement : Let,1,[VAR#1]-1 in:
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
   TimerSet,8,1
  EndOn
I have also created a dummy device (nb 2) with 4 variables.I think that I should see something with : http://x.x.x.x/json?tasknb=2:
{"System":{
"Build": 20000,
"Unit": 0,
"Uptime": 4177,
"Free RAM": 21904
"Sensors":[
"TaskName": "Relai",
"Relai": 0.00
"TaskName": "countdown",
"%v1%": 0.00,
"[var#1]": 0.00,
"tt": 0.00,
"var#1": 0.00
I will continue exploring the forum again this weekend.
As you can see, I am a little bit lost :)
Gilles
#7 Post by grovkillen » 07 Mar 2019, 10:35
I need to fully understand exactly what you want. Do you want the timer value (remaining time) to be used in a dummy variable/task/value (just call it "dummy" :) ) or do you just want to show it on a display or whatever?
To explain this part:
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
 TimerSet,8,1
EndOn
Let,1,[VAR#1]-1 means that you assign internal variable number 1 with its own value minus 1 (since it's now one second since last time we ran the timer number 8).
After we set the variable to this new value we reset the timer for another second.
Why we use square brackets? To process float and integers formulas in rules (digits/numbers) we need to specify it using those [..]. If we on the other hand want to use it elsewhere (like in plugin formulas etc.) we need to use percentage signs %..% instead. This is legacy coding, we know it's not super clear at first glance.
So if I understand you correctly you want to post the remaining time to your dummy device you have on task number 2, and since the dummy have 4 values to post to I pick the first one in this example:
On Relai#State Do
 If [Relai#State]=1
    TimerSet,1,7200
    TimerSet,8,1
    Let,1,7200
  Else
    TimerSet,1,0
    TimerSet,8,0
    Let,1,0
  EndIf
 EndOn
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
  TimerSet,8,1
EndOn
PS in this example I renamed your value name from Relai to State, I find it not logical to have the same task name as the value name. I understand you have a switch plugin which is monitoring the relay state. When this state changes you look and see if this new state is 1, if so you start a timer (7200 seconds). We then set a second timer (I picked timer number 8 for this, I always do that for those "keeping track of" timers) and set that to 1 second. Right after that we set the internal variable number 1 to the same amount of seconds as the count down timer (7200).
When the timer number 8 reaches zero it'll update the internal variable number 1 to a new value which is it's previous value ([VAR#1] which is 7200) and subtract 1 from that. This means that the value of [VAR#1] now is 7199. And after that we reset the timer number 8 to 1 second. After a second this repeats and the new value of [VAR#1] is 7198.
If the Relay#State changes during this time the rule will set the timer 1 and timer 8 to zero meaning that they are disabled, after that the also set the [VAR#1] to zero using the Let,1,0 command.
IF you want to post your value of [VAR#1] to the dummy on task number 2 and it's value number 1 you add this to the code:
On Relai#State Do
 If [Relai#State]=1
    TimerSet,1,7200
    TimerSet,8,1
    Let,1,7200
    TaskValueSet,2,1,[VAR#1]
  Else
    TimerSet,1,0
    TimerSet,8,0
    Let,1,0
  EndIf
 EndOn
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
  TimerSet,8,1
EndOn
Gilles
#8 Post by Gilles » 07 Mar 2019, 12:07
Thanks for the detailled info.
What I want : I use a sonoff with espeasy to switch on a light in the garden with a timer = 2 hours . I trigger this with a rule. And 2 hours later, when the timer equals 0 , I switch off the light with another rule. This works fine.
Now, I just would like to know if it is possible to get the time left (the value of the timer) with a http command like http://x.x.x.x/control?cmd=status,"time_left" or anything.
I don't use (yet) openhab, domotiz or any other domotic software.
I just would like to create a brower shortcut to query the timer value.
#9 Post by grovkillen » 07 Mar 2019, 14:12
You can get the time left using a dummy variable like you tried to but how do you want it presented? Do you log in to check this value or do you want it displayed some other way? Do you want it automatically?
You could simply create a html file with this code inside. Change ip number and change the sensor + task number to match your setup, and it'll fetch the values for you.
The "magic" happens here...
<script>
let ip = 'XX.XX.XX.XX';
setInterval(function() {
let ud = 'id_' + +new Date;
let url = 'http://' + ip + '/json?callback=' + ud;
fetch(url)
    .then(res => res.json())
    .then((jsonData) => {
        console.log('Output: ', jsonData);
		document.getElementById("timerValue").innerHTML = jsonData.Sensors[0].TaskValues[0].Value + ' sec';
}).catch(err => console.error(err));
}, 1000);
</script>
example.zip
(3.51 KiB) Downloaded 768 times
Gilles
#10 Post by Gilles » 07 Mar 2019, 17:05
wow, I am really impressed with what you can do with espeasy. Thanks for your great explanation.
Unfortunately, it doesn't work for me. the dummy device values remain empty.
Here is the device section:
here is the rule section (with relay#relay ,not yet changed):
on toto do
 if [Relai#Relai]=1
 gpio,12,0
 gpio,12,1
On Relai#Relay Do
 If [Relai#Relay]=1
    TimerSet,1,7200
    TimerSet,8,1
    Let,1,7200
  Else
    TimerSet,1,0
    TimerSet,8,0
    Let,1,0
  EndIf
 EndOn
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
  TimerSet,8,1
EndOn
I trigger the rule with : http://192.168.1.6/control?cmd=event,toto
The light switches on and will switch off 2 hours later.
Let's say that I don't remember at what time I have run the command : http://192.168.1.6/control?cmd=event,toto
I would like to be able, on demand , to know how much time is left by typing something like : http://192.168.1.6/control?cmd=status,xxx ?? in the same way as I can get the gpio status with : http://192.168.1.6/control?cmd=status,gpio,12
I could also use something like : http://192.168.1.6/json?tasknb=2 and split the json to get the value I am interested in.
#11 Post by grovkillen » 07 Mar 2019, 17:14
Study your names and you'll see what's going on. (That's why I never use same names for tasks and their values).
Gilles
#12 Post by Gilles » 07 Mar 2019, 17:29
got it : relai(french) and relay(English)
The eye of the tiger :)
Gilles
#13 Post by Gilles » 08 Mar 2019, 10:24
Sorry but It doesn't work yet. the dummy device value remains 0.The four value names are : dummy, tv2, tv3, tv4)
Any idea ?
here is the rule: ( I trigger it with : http://192.168.1.6/control?cmd=event,toto )
on toto do
 if [Relai#Relai]=1
 gpio,12,0
 gpio,12,1
 endon //http://192.168.1.6/control?cmd=event,toto=30
On Relai#Relai Do
 If [Relai#Relai]=1
    TimerSet,1,7200
    TimerSet,8,1
    Let,1,7200
  Else
    TimerSet,1,0
    TimerSet,8,0
    Let,1,0
  EndIf
 EndOn
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
  TimerSet,8,1
EndOn
Here is the log: I am wondering if there is an issue with [VAR#1].
60180103 : EVENT: countdown#dummy=0.00
60181005 : EVENT: countdown#tv2=0.00
60181907 : EVENT: countdown#tv3=0.00
60182819 : EVENT: countdown#tv4=0.00
60183727 : EVENT: Clock#Time=Fri,10:16
60184632 : EVENT: Rules#Timer=8
60185330 : ACT : Let,1,-1
60185536 : ACT : TaskValueSet,2,1,
60185542 : ACT : TimerSet,8,1
#14 Post by grovkillen » 08 Mar 2019, 11:47
Setting the GPIO to something will never trigger the relay task.
GPIO is changing the value internally, only externally will invoke the event Relai#Relai (ps you should really not name them the same).
Try this to trigger an event:
on toto do
 if [Relai#Relai]=1
 gpio,12,0
 gpio,12,1
 Event,Relai#Relai
Gilles
#15 Post by Gilles » 08 Mar 2019, 13:43
it doesn't work either.
I have renamed the status and rewritten the rule to make it simpler.
On toto Do
 If [Relai#Status]=0
    gpio,12,1
    TimerSet,1,7200
    TimerSet,8,1
    Let,1,7200
  Else
    gpio,12,0
    TimerSet,1,0
    TimerSet,8,0
    Let,1,0
  EndIf
 EndOn
On Rules#Timer=8 Do
   Let,1,[VAR#1]-1
  TimerSet,8,1
EndOn
The logs says :
72281227 : ACT : TaskValueSet,2,1,
72281233 : ACT : TimerSet,8,1
72285192 : EVENT: Rules#Timer=8
72285853 : ACT : Let,1,-1
72286061 : ACT : TaskValueSet,2,1,
72286068 : ACT : TimerSet,8,1
72287194 : EVENT: Rules#Timer=8
72287860 : ACT : Let,1,-1
72288064 : ACT : TaskValueSet,2,1,
72288071 : ACT : TimerSet,8,1
The device section shows:
When i trigger the rule, then Relay device value becomes = 1 , the light is switched on.
There should be something wrong, that I don't see...
What do you think about the value of [VAR#1] not shown in the log. Is it normal?
Gilles
#16 Post by Gilles » 08 Mar 2019, 13:49
I have just added a line in the rule to assign the value 300 to the variable number 2 (tv2) and I can see it in the device section.
On toto Do
If [Relai#Status]=0
gpio,12,1
TimerSet,1,7200
TimerSet,8,1
Let,1,7200
TaskValueSet,2,2,300
Else
gpio,12,0
TimerSet,1,0
TimerSet,8,0
Let,1,0
EndIf
EndOn
On Rules#Timer=8 Do
Let,1,[VAR#1]-1
TimerSet,8,1
EndOn
#17 Post by grovkillen » 08 Mar 2019, 13:56
Sounds like a bug!
Gilles
#18 Post by Gilles » 08 Mar 2019, 13:59
I may need to upgrade to a more recent version.
I may do it this weekend. I will add a post when done.
Thanks for your help and time.
Much appreciated
Gilles
Gilles
#19 Post by Gilles » 08 Mar 2019, 14:27
BTW,
what would be the http command to get the value of tv2 (second value of the second device)
Is it : http://192.168.1.6/json
or is there a query which return directly the value of tv2
ex something like : http://192.168.1.6/control?cmd=status,countdown,2,2
#20 Post by grovkillen » 08 Mar 2019, 14:41
You want the value in in what system? Everything is possible to do, but how you do it are different depending on your case.
Gilles
#21 Post by Gilles » 08 Mar 2019, 14:51
I was thinking to something(url) that I could type in a browser on my smartphone or laptop. I already have a shortcut to trigger the rule (http://192.168.1.6/control?cmd=event,toto).
Another browser shortcut to have the timer value displayed should be great :)
#22 Post by grovkillen » 08 Mar 2019, 14:58
Download the zip I attached in the message some lines above... There you have the JavaScript to do it inside a browser.
Gilles
#23 Post by Gilles » 08 Mar 2019, 15:22
I had tested it , but i only get a blue background.
I have edited the example.html file changed the blue lines.
<script>
let ip = '192.168.1.6';
fetch(url)
document.getElementById("timerValue").innerHTML = jsonData.Sensors[2].TaskValues[2].Value + ' sec';
#24 Post by grovkillen » 08 Mar 2019, 15:35
Change those 2 to 1... In programming we start counting at zero.
Gilles
#25 Post by Gilles » 08 Mar 2019, 15:43
It doesn't work for me with Chrome.
The inspect console shows some errors
Really sorry,
Gilles
#26 Post by grovkillen » 08 Mar 2019, 16:18
If the task is on the first value then it should be:
jsonData.Sensors[1].TaskValues[0].Value + ' sec';
And people, please experiment...
Gilles
#27 Post by Gilles » 08 Mar 2019, 16:36
you are right, In my case, it is the second sensor and the second value so it should be jsonData.Sensors[1].TaskValues[1].Value + ' sec'; I have even tried several combinations.
Maybe there is something wrong with the espeay version that I run.
Don't worry, I will write a python script to get the json and extract the value of the sensor.
Gilles
#28 Post by Gilles » 09 Mar 2019, 08:44
I have upgraded the sonoff esp to: ESPEasy_mega-20190225
Everything works as it has to.
I can get the dummy variable
and your java script is fantastic:)
NB: the json display shows a lot of detailed info with this espeasy version.
Thanks a lot
Gilles
#29 Post by grovkillen » 09 Mar 2019, 09:25
Thanks for getting back with the feedback! :D
manjh
#30 Post by manjh » 22 Jun 2019, 12:24
If I understand correctly, in the examples you use a variable to run in parallel to a timer. This value in the variable can then be used.
But there must be a way to directly copy the remaining value of the timer into a variable?
I tried, but no success... am I missing something?
#31 Post by grovkillen » 22 Jun 2019, 20:09
Currently there's no way of getting the value directly.
manjh
#32 Post by manjh » 22 Jun 2019, 22:56
grovkillen wrote: 22 Jun 2019, 20:09 Currently there's no way of getting the value directly.
Jimmy, sounds like an item on the development list. Being a professional IT person, the solution with a var running in parallel with the timer seems like a less beautiful workaround..
#33 Post by grovkillen » 22 Jun 2019, 22:57
Yep, agree. Will you open a feature request on GitHub?
Gilles
#34 Post by Gilles » 18 Jan 2024, 06:30
@Grovkillen,
do you know if today the value of a timer can be displayed as part of the json query or using a http request ?
I remember having posted the request some years ago.
NB: I have just read your last answer requiring to open a feature on GitHub.
#35 Post by TD-er » 18 Jan 2024, 08:20
Have you also looked at the dashboard made by chromoxdor, called "EasyFetch"?
https://github.com/chromoxdor/easyfetch
What do you need in the JSON or perhaps as a rules command to store in a variable?
Gilles
#36 Post by Gilles » 19 Jan 2024, 06:11
Finally, I have used the Grovkillen's script (zip attached somewhere above) along with a Dummy device. I works fine and fits my requirement. Not sure to understand how does it work but it works :)
Thanks for your tips.
Gilles
ezparce
#37 Post by ezparce » 08 Jul 2024, 07:11
I try to use the shared script, without success. Can you share your html file that works for you?
Thks
#38 Post by Ath » 08 Jul 2024, 08:31
ezparce wrote: 08 Jul 2024, 07:11 I try to use the shared script, without success. Can you share your html file that works for you?
A lot of useful/beautiful dashboards can be built using the EasyFetch scripts by user chromo23, found in this thread. And that is also in active maintenance, the script above is kind of frozen.
