MPR121 touch sensor
nobody@all
MPR121 touch sensor
#1 Post by nobody@all » 17 May 2019, 19:48
Hello!
Is this sensor Capacitive Touch Sensor Controller Module I2C keyboard
works with espeasy mega-20190511?
I found some information here and here but can't make it work.
Conneected :
SCL- GPIO12 (D6)
SDO- GPIO13 (D7)
Device- Keypad - TTP229 Touch
Re: MPR121 touch sensor
#2 Post by grovkillen » 17 May 2019, 22:43
It's not the same IC as the plugin?
nobody@all
#3 Post by nobody@all » 17 May 2019, 22:54
IC on my board MPR121
IC in espeasy mega-20190511 -TTP229
but Plugin 062: MPR121 KeyPad says it should work properly but i don't see it in devices in espeasy.
#4 Post by grovkillen » 18 May 2019, 08:39
Which version are you running? Test?
nobody@all
#5 Post by nobody@all » 18 May 2019, 11:36
Finally i found some old firmware on my laptop. mega-20180421 in test version there is MPR121 sensor and it work properly.
Only one issue- if we set up this sensor but do not connect it esp will not boot up.
#6 Post by grovkillen » 18 May 2019, 11:59
Please file an issue on GitHub.
