Hi there.
Not really an ESPEasy problem but maybe this can arrive to someone.
Using nodemcu 12e & Wemos mini d1 on arduino IDE 1.6.5 and esp8266 environnement 2.1.0 rc1
I try some Esp Sketch and now i'm facing a problème :
A sketch start to load and run well util it retrive an previous sketch configuration store on memory and then enter on a bootloop
Message is :
Rest 2 mode 3,6 or reset 2 mode 3,7
I simply want to clear all esp8266 memory ans start from a brand new like bords.
Do you have some tips please ?
[Solved] Esp8266 clear eeprom and spiffs.
Re: Esp8266 clear eeprom and spiffs.
i had some clearance of the flash with R076, it think.
the arduino ide showed the end of flashing, but in the serial-monitor the erase was still running a while.
check the R07x version? Downgrade to R048, than upgrade to R07x?
flash first nodemcu, than flash ESPeasy after?
Thanks for tips and thanks team for r48 who solve my probleme.tozett wrote:i had some clearance of the flash with R076, it think.
SOLVED: Esp8266 clear eeprom and spiffs.
maybe this thread should be marked as SOLVED by ADMIN or threadstarter?
