[Solved] Esp8266 clear eeprom and spiffs.
Deennoo
#1 Post by Deennoo » 01 Feb 2016, 18:50
Hi there.
Not really an ESPEasy problem but maybe this can arrive to someone.
Using nodemcu 12e & Wemos mini d1 on arduino IDE 1.6.5 and esp8266 environnement 2.1.0 rc1
I try some Esp Sketch and now i'm facing a problème :
A sketch start to load and run well util it retrive an previous sketch configuration store on memory and then enter on a bootloop
Message is :
Rest 2 mode 3,6 or reset 2 mode 3,7
I simply want to clear all esp8266 memory ans start from a brand new like bords.
Do you have some tips please ?
tozett
Re: Esp8266 clear eeprom and spiffs.
#2 Post by tozett » 01 Feb 2016, 18:59
i had some clearance of the flash with R076, it think.
the arduino ide showed the end of flashing, but in the serial-monitor the erase was still running a while.
check the R07x version? Downgrade to R048, than upgrade to R07x?
flash first nodemcu, than flash ESPeasy after?
Deennoo
#3 Post by Deennoo » 01 Feb 2016, 21:14
tozett wrote:i had some clearance of the flash with R076, it think.
Thanks for tips and thanks team for r48 who solve my probleme.
tozett
SOLVED: Esp8266 clear eeprom and spiffs.
#4 Post by tozett » 02 Feb 2016, 09:10
maybe this thread should be marked as SOLVED by ADMIN or threadstarter?
