Has anyone tried this OLED: https://www.aliexpress.com/item/Wholesa ... sstype=600
I cant get it work. Nothing happens when I tired it
-macke- wrote: ↑19 Apr 2017, 16:04 Hello!
I cant get it work. Nothing happens when I tired it![]()
Indeed the 0603 SMD resistors are extremely small but you have to remove R17(4k7) and solder a resistor with a value between about 1k and 10 k on the place of R15 otherwise the display might not be recognized as I2C.
Yeah that I2C-only OLED is perfectly fitted for use with ESPEasy.totof60 wrote: ↑18 May 2017, 09:42 I buy this one http://www.wide.hk/index.php?route=prod ... duct_id=67
And no need soldering , work fine
Great info! I got this OLED like half a year ago and only switch the R17 with R15.. did not short/bridge the other positions and the i2c scanner went bananas. I just left it at that. I will use your info and hopefully get it up and running. Thanks!costo wrote: ↑13 May 2017, 23:56 You have to prepare the board before it will work:
Remove R17 and place it on position of R15
Solder a short or 0 ohm on position R13
Solder a short or 0 ohm on position R18 or connect the CS pin to ground
Connect the OLED display to the ESP with Gnd, 3.3V, SCL and SDA
also connect the RES pin of the OLED display to the ESP_reset_pin. (or 3.3Vcc)
Did you try connecting them together but NOT to ground?connected DC and CS to ground
Users browsing this forum: Bing [Bot] and 15 guests
