ESP Board and Power via Battery
popperchris
#1 Post by popperchris » 23 Aug 2019, 09:45
Hi all
i use a ESP Board to Masure Temp, Humidity and Air pressure.
The Place to use a Power Supply is not a Good Place. The sun shines directly on the ESP board in the morning. A good Place is without Power.
Use a power bank from you and can share with me experience how long it lasts before it needs to be loaded!!
Christoph
dynamicdave
Re: ESP Board and Power via Akku
#2 Post by dynamicdave » 23 Aug 2019, 10:22
What's an Akku ????
Is it possible to put the ESP board in the shade and power it from a solar panel ???
One of my students has made a solar-powered weather station using a Wemos D1 Mini (ESP8266 running ESP-Easy).
He puts the board to sleep for 15-minutes (to save energy), then when it wakes up it takes some measurements and publishes them to Node-RED via MQTT, then goes to sleep.
If you want to try running it off of a powerbank then the time it will last depends on the mAh capacity of the powerbank.
Before he decided on using a solar panel he tried a powerbank and it only lasted 2 or 3 days before it needed charging.
Hope this helps.
PS: I can send you links to the solar-powered weather station if you are interested.
#3 Post by TD-er » 23 Aug 2019, 13:11
An "Akku" is probably German for "battery". :)
If heat, or temperature in general, is an issue. Then you should for sure not start using batteries.
That's a fire hazard waiting to happen.
You've probably seen temperature protection kicking in on a smart phone or car navigation. Those are there for a very good reason.
werner_g
Re: ESP Board and Power via Battery
#4 Post by werner_g » 24 Aug 2019, 15:36
still, common in German is a battery but when saying 'Akku' (Akkumulator) we mean a rechargeable one.
@ dynamicdave: I woud like to see your links for the solar-powered weather station, especially for the rules.
dynamicdave
#5 Post by dynamicdave » 24 Aug 2019, 19:43
Here's the link to the project on Discourse Node-RED.
https://discourse.nodered.org/t/solar-p ... n/12499/73
The project was split into six managable stages.
I hope you find this useful.
#6 Post by TD-er » 24 Aug 2019, 23:47
werner_g wrote: 24 Aug 2019, 15:36 still, common in German is a battery but when saying 'Akku' (Akkumulator) we mean a rechargeable one.
In Dutch we also use "accu" for rechargeable ones.
But sadly the word "battery" and "accu" are very often mixed in conversations in Dutch.
