esp easy connecting to home network
Tim-
#1 Post by Tim- » 08 Feb 2016, 14:13
First all the necessary information:
Arduino version 1.6.5
i used the: ESP8266-07
Connected: GND - GND
GPIO15 - GND
GPIO2 - 3.3V
GPIO0 - 3.3V
EN - 3.3V
VCC - 3.3V
DS18B20 connected:
GND - GND
VOD - 3.3V
DQ - GPIO12
the problem:
I followed this tutorial:
http://www.esp8266.nu/index.php/Tutoria ... are_Upload
after flashing ESPEasy R048 i configured the esp8266 so that it is connected to my home-network.
But if i add the DS18B20 to the Device list. The esp8266 disconnects from my home-network and appears in the network selections as an stand-alone network and is it only accesible by 192.168.1.4.
What is the best way to connect and configure this so it is accesible in my home-network.
tozett
Re: esp easy connecting to home network
#2 Post by tozett » 08 Feb 2016, 14:42
maybe you want to give the lastest firmware a try?
dont know, but maybe your problem is already solved since R048 to R078?
here latest stable:
http://www.esp8266.nu/index.php/Main_Page#Stable
Tim-
#3 Post by Tim- » 09 Feb 2016, 09:49
i will give that a try
i heard that if i am gonna use this firmware i don't have to flas the esp8266 but how do i put the right firmware on the esp?
never mind i know i have to use the flash tool
Tim-
#4 Post by Tim- » 09 Feb 2016, 13:37
it works :D
The esp is now connected to my network and the ds18b20 is added by the device list.
Now i can figure out how the ds18b20 will display the right temperature instead of 0.00.
thanks!
tozett
#5 Post by tozett » 09 Feb 2016, 18:39
seems SOLVED here...
Backbone
#6 Post by Backbone » 09 Feb 2016, 18:43
Place IDX number other then zero 0.
tozett
#7 Post by tozett » 09 Feb 2016, 18:50
if this is the reason, than you are another one how stumpled upon this idx-feature
sometimes i wished me a clearer gui for reading+sending/not sending
8-)
http://www.esp8266.nu/forum/viewtopic.p ... ding#p3687
Tim-
#8 Post by Tim- » 10 Feb 2016, 09:47
It is already solved :D
i figured out the picture with the pinout was backwards and the pins were connected to the wrong pin :oops:
but thanks for helping!
