ronilee
#1
Post
by ronilee » 06 Mar 2020, 17:18
Hello!
I have a new UV Sensor VEML6070.
I use EasyESP to send the data to domoticz. (HTTP)
My problem:
This sensor has three values, UV-Raw / UV-Risk / UV-Power
I have created a virtual custom sensor, but the only shown me the first value UV-Raw.
Do you have an idea how i can display the 2 and 3 value?
Thanks a lot
#2
Post
by TD-er » 06 Mar 2020, 17:47
The custom sensor in Domoticz only supports a single value and the rest will be ignored.
For this you can send the other two by generating the HTTP URL for sending it to Domoticz and send it from the rules using sendtohttp. (or via publish by sending it to MQTT broker)
As trigger you can use the name of the task, so those other values will be sent right after the first value is sent via the controller.
ronilee
#3
Post
by ronilee » 06 Mar 2020, 18:26
Thanks a lot for the fast answer.
What reassures me is that there is a solution.
But i don´t understand your solution.
Can you a bit more precise?
What i make in ESPeasy and what i must make in domoticz.
#4
Post
by TD-er » 06 Mar 2020, 20:14
See the (old) documentation on the wiki:
https://www.letscontrolit.com/wiki/inde ... rial_Rules
Almost at the bottom of that page is described how to send data from the rules to Domoticz.
What you need is the IDX value of the charts in Domoticz and the taskname#varname where your values are at.
So for example if you have a task called "BME280" (values named: temp/hum/baro) and you would refer to the second value, you refer to it as [BME280#hum]
For an introduction to rules, see:
https://espeasy.readthedocs.io/en/lates ... Rules.html
ronilee
#5
Post
by ronilee » 07 Mar 2020, 08:23
That's what i was looking for.
It works
Fine
Thank you very much
Greetings from Austria
pe1fam
#6
Post
by pe1fam » 25 Oct 2020, 13:41
It should be somthing like this I guess:
on [VEML6070#UV-Risk] do
Publish domoticz/in,{"idx":438,"nvalue":0,"svalue":"[VEML6070#UV-Risk]"} //Own made up IDX 438
on [VEML6070#UV-Power] do
Publish domoticz/in,{"idx":439,"nvalue":0,"svalue":"[VEML6070#UV-Power]"} //Own made up IDX 439
However this does not work (included TESTING, UV - too), probably I made a stupid mistake, do have a suggestion?
#7
Post
by Ath » 25 Oct 2020, 14:03
Try this version of your script:
pe1fam wrote: ↑25 Oct 2020, 13:41
on VEML6070#UV-Risk do
on VEML6070#UV-Power do
The `on x do` statements shouldn't use the square braces, as the rules engine will then replace that with the value of the sensor. The name of the event is actually 'VEML6070#UV-Risk' etc., so that is what should be in the statement.
#8
Post
by TD-er » 25 Oct 2020, 14:45
Also make sure not to use a minus character in the task name and/or taskvalue name.
pe1fam
#9
Post
by pe1fam » 25 Oct 2020, 15:06
It was that easy, this works..
on VEML6070#UV-Raw do
Publish domoticz/in,'{"idx":438,"nvalue":0,"svalue":"[VEML6070#UV-Risk]"}'
Publish domoticz/in,'{"idx":439,"nvalue":0,"svalue":"[VEML6070#UV-Power]"}'
The '{ bla }' part needed single quotes, maybe documentation need an update.
The log option did tell me that the publish rule was not correct.
And indeed the on [ ] hooks needed to be removed (that was my in my first script to, so the main problem was the quotes)
Maybe this has to do with the testing version (VEML6070 was in that version)?
Thanks all
#10
Post
by Ath » 25 Oct 2020, 15:43
TD-er wrote: ↑25 Oct 2020, 14:45
@TD-er: Maybe this validation should be (re-)enabled in the test builds as well? Despite the slightly larger bin files, this does seem more and more important...
#11
Post
by TD-er » 25 Oct 2020, 15:45
Yep we really need to re-evaluate what should be included in what build as it is becoming quite confusing right now.
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot] and 20 guests
